Question about Broan-NuTone VX475 Bagged Central System Vacuum
I have the same central vac and the same problem
Let me know what the company says. I'm about to smash this central vac unit to pieces.
  • A Miller May 11, 2010
    do you have a question?
I use the vac for 5 min then shuts off , wont start for another 10min , the filter is clean and the container is empty, the vents are not blocked ,what else could it be? thanks nick
Posted on Jul 10, 2010
  • bandit_1086 Feb 20, 2011
    Its a problem with the Main Control Board Assembly. Nutone switched to a cheaper "made in China" board (and motor) and have had problems with them ever since. If you have your sales receipt they should honor the warranty and possibly ship you a new unit, if you don't you're S.O.O.L. because they have had to replace almost every unit and they are trying to cut their losses by demanding the original receipt proving you bought it.
  • 430 Answers
I don't see a problem. here. Post details and I'l be glad to help ASAP
Posted on Oct 04, 2009
Central Vac Dust Care 3000C - My system will not turn off when I unplug the hose. I also tried unplugging the low voltage wires from the unit and it will not turn off . Any thoughts?
A hanging relay, put a piece of paper between the magnet and the actuator, it releases quicker. Or there is a short in the wire, measure if there is a voltage over the wire, if not there is a short somewhere, good luck!
Dec 05, 2011 | Central Vac Dust Care 3000 Bagless System...
On my M&S Air Vac AV425 central vaccuum system, the system usually turns on by inserting the vaccuum hose into one of the vaccuum outlets. However, it now runs continuously. I am able to turn it off...
we are a central vacuum service company and we service all of new jersey. sounds like you have a short some where that keeps your unit running or it could be your relay module thats stuck our number is 908-721-7595 its j&j central vacuum services
Dec 28, 2010 | Vacuums
AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Apr 21, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Central vac
It is possible that the low voltage wiring that controls your central vacuum has been damaged during the cable work. You can check to see if the low voltage relay is working by shorting the two terminals together at the unit. Just disconnect the two small (18-22 gauge) wires from the unit and short across the terminals where the wires connect. If the unit comes on, the vacuum is fine, and it is most likely the low voltage control wires that have been damaged. It should be a pretty easy fix, if you can get to where the wires are located. They are probably just pulled apart at a joint. Good Luck!!
Jul 10, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Wireing up central vac too braker box.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=579196
Generic problem for all Vacuums
Wiring up central vac too
Posted by brneault on May 08, 2008
Wiring up central vac too breaker box.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
A central vac not knowing the brand name or model # uses regular household current and plugs into a regular household inlet and I have never heard of wiring the central vac to the breaker box. The central vac is usually out in the garage or down the basement and will be in the regular household current. You may want to ask the manufacturer or the vac dealer you purchased the central vac from and they might have more information for your and if your central vac needs to be wired to the breaker box they will give you instructions, but I don’t believe that you need to do so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Vacuums
Central vac toast?
Most of these motors, the fan cover is just pressed on, but getting off isn't easy and you don't want to bent it up. Maybe using a flatblade try to knock it off from the edge of it may loosen it enough to pull it off.
Mar 18, 2008 | Vacuums
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
319 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
