Question about CorningWare SC60 Slow Cooker
My slow cooker wont work. Had it for 5 months used it 2 times and the time I used it I put the ingredients in and set it for 10 hours on low and when I came home it was never hot .It does not get hot. I plugged it everywhere it lights up and the buttons work but the heat does not. Please tell me what to do. Never got the inside wet!
    Genius:
  • 1,460 Answers
Sounds like internal thermal fuse could have gone / or element....If you still have receipt take it back..Cheers
Posted on Oct 04, 2009
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Please tell me how this appliance works. Thank you. Mary Jane Howroyd Kitchen Aid Crock Pot
    Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
    Dec 27, 2010 | KitchenAid Crock Pots & Slow Cookers
    Slow cooker will only stay on warm. How do I put
    This slow cooker has 3 settings LOW, HIGH, & WARM
    When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
    If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
    Feb 11, 2010 | CorningWare SC60 Slow Cooker
    How do I start the cooker on low?
    The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
    The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
    If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
    To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
    If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
    Dec 18, 2009 | CorningWare SC60 Slow Cooker
    Need a manual for the corningware sc60
    The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
    Nov 28, 2009 | CorningWare SC60 Slow Cooker
    The outside of my slow cooker gets very hot, is that normal? Also, on the low setting the ingredients seem to at a pretty high boil.
    Yes, many models have hot outsides. To check temp, fill with water, put on low for 1 hour, check with an instant read thermometer. If it is over about 200 (normal low temp), your pot is running very hot.
    Nov 24, 2009 | WeatherWorks CH-9350 Slow Cooker
    No manual for my old Crock Watcher by Proctor Silex
    The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
    Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
    Oct 19, 2009 | Crock Pots & Slow Cookers
    Can't change temperature-stays on "warm"
    Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
    May 19, 2009 | CorningWare SC60 Slow Cooker
    Corningware slow cooker 6qt
    If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
    Aug 22, 2008 | Crock Pots & Slow Cookers
    CorningWare SC60 Slow Cooker Logo
    148 people viewed this question
    Top CorningWare Crock Pots & Slow Cookers Experts
    charles
    Gerry Harvey
    Gerry Harvey
    raysaw
    Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
