Question about Kenmore 95002 / 95004 Electric Kitchen Range
The stove doesn't acknowledge power, no what? We checked the wires already and the fuse is good....
    Sergeant:
  • 316 Answers
Did you make sure the wall outlet has power?
Posted on Oct 04, 2009
My farenheat fu54 heater just stopped working. Power to it is fine any suggestions on how to diagnose the problem
you said it has power, is it before or after the wire from the fuse you have checked, check the power wire that goes after the fuse. the fuse may need to replace, and if all is good and still does not work. check also the thermal cutout, This device protects the unit from overheating, it may already faulty (it may be always in off if its already faulty), here's other to look for , power supply, heating element, Power switches, thermo couple(if any), sensors..
Nov 24, 2014 | Cars & Trucks
Why is my pellet stove blowing fuse when plugged in
There can be several reasons. It would help me to know what make and model, but heres a start.....1} Make sure your using the correct fuse.2} Look for any debris or items which have entered the unit that could be shorting out the circuit. Also look for loose connections or wire spades that have come loose and shorted 3} Next see if the combustion and convection blower is turning freely. They should spin with ease. If in doubt, make a test cord from an old extension cord and try the blower directly by DISCONECTING it from the stove wiring and hooking the test cord to it then plug into a power strip carefully.4} Check the auger... Can you wiggle it around with your hand? If so then use the test cord in the same fashion as the blower. Augers tend to jam up and that can blow the fuse depending on the make of stove. 5} Look at the igniter and wire to assure that it is in visibly good condition. These are some good places to start. If none of these are help, it may be worth while to call a repair tech or manufacture help line. Be prepared for a long hold if you call during peak winter season. Good luck.
Jun 14, 2014 | Drolet ECO-45 High Efficiency EPA Pellet...
Amana Stove just stopped working
Could be the fuse in the back turn off the power and trace the wiring with a multimeter, when you stop getting continuity there is the fuse.
Good luck Ray
Apr 15, 2014 | Amana 30" Self Cleaning Electric Range...
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Broil element just warm, bake element not working
Hey -have ya tried checking the power block on the back of the stove? This is the first thing I check when power appears to be uneven. Connections may be loose enough to disrupt power flow to the elements. If wires look good, the next step is to find out if the bake element has failed. From the back you can see the wires that attach to the element. Disconnect and check resistance.  should be around 17-19ohms. If not replace with new.  Please acknowledge this post if the info was helpful. Have more if needed  Thanks-- Ed
Mar 20, 2010 | Moffat Ovens
No power
If you mean absolutely no juice and haven't done so already, you need to check the breaker or fuse first. If the breaker/fuse is off flip the switch and try the oven. If the fuse trips again, you have a short someplace.
Obvious places would be the cord and outlet. To check these, turn the power off again and pull the stove out. Follow the cord and check it for broken areas areas. Then look at where it connects to the stove. Check the outlet and make sure that is intact.
If you see no problems with the outlet, the easiest way to check it without a tester is to simply plug another device into it.
Dec 23, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Stove don't work at all
CHECK THE POWER IN THE WALL MAY BE BURNT
Apr 27, 2009 | Ovens
HOOKING UP STOVE TO POWER OUTLET IN HOUSE....
you need to take the back of.down the bottom should be power terminals.positive ,earth and negative,earth is green,negative is black or blue.the earth is to be puy on thee screw.if you undo a screw then the wires will clamp in when screwed back.a stove should be hard wired to the house if you use a power leadto a power point you can not use all of the stoves functions ,it will trip the fuses
Sep 25, 2008 | GE JDS26 Electric Kitchen Range
Kenmore 95002 / 95004 Electric Kitchen Range Logo
95 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
