How do you change the right front burner??
SOURCE: inner burner -- front right burner - does not heat up
You will have to check your stat.this is the switch which controls the power to both parts of the ring.It may be faulty.This is a thermostatic switch.It can be checked with a mains test lamp.If this is ok then check the spade terminals are still intact at the ring itself.
