Question about Dryers
We are trying to replace the belt to our front loader dryer DLE5977W and are not sure how to take the dryer apart. Do we start from the front or the back.What steps do we need to replace the belt. Thank You.
  • Dryers Master
  • 7,482 Answers
If it is a front loading machine:
You would remove the front of the machine, that will expose the drum and belt, remove the drum and belt and that will expose the drum rollers,motor, idler arm pulley.
Before you replace the drum and belt assembly, Check you drum rollers for flat spots, If they have flat spots on them replace them. I would also recommend that you lubricate your drum rollers with a good quality of machine oil such as 3 in One Oil. This will save you later on another disassembly because of noisy drum rollers.Apply the oil at the shaft of the drum rollers.
I hope this helps
Posted on Oct 04, 2009
LG DLE5977W dryer - thumping
its not the belt its the rollers you can get a kit that the belt the tensioner pulley and the rollers all come together if your replacing the rollers seeing how you already have everything apart u might as well just install the kit if your belt were broke youd have no spin you can order these from marcone or allbrands appliance they willmail the parts directly to you hope this helps
May 01, 2010 | LG DLE5977 Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Front loader Electric Dryer the belt
It's not that hard, but it can be a little tricky. First UNPLUG the dryer or turn off the gas to it, whichever is applicable.
Then, assuming you have the new belt, you will open the lint filter door. There will be two screw heads visible. Remove them. Place a knee in the center of the dryer just below the top. Place your hands at the front corners and **** hard while pressing with your knee and lift up on the top of the dryer. Once you do this, tilt the dryer top back until it rests on the wall behind the dryer.
Next remove the two bolts at the top front corners. Disconnect the wiring harness connector for the door switch and lift the front panel of the door up and away from the rest of the dryer. You will notice the drum rides on the front panel and will fall down.
Take out the old belt. Loop the new belt around the drum in the same approximate position that the old belt was riding. Take a small loop of belt and push it through the tensioner while lifting the tensioner to relieve tension off the belt. Then loop that end around the motor pulley.
To re-assemble the dryer, reverse the directions for taking it apart. Remember to hook up the wiring harness. You will have to lift the drum into place to make sure the felt on the front and rear ride correctly on the guides.
Jun 24, 2009 | Dryers
ELECTRIC XL LOAD CAP DLE5977W
You gave me the best info to let my repair man know the problem. I cannot get to the belt and have been told it is a pretty big job and my dryer is still under warranty..so they are fixing it for me this week. Thank you for the information, it was helpful.
May 02, 2009 | LG Dryers
Felt has come off drum DLE5977W
you can't take the back of the dryer off you must take off front pop the top remove the the front take out drum and belt replace felt. Replace drum belt front and top thank you for useing fixya please rate me
Feb 10, 2009 | LG DLE5977 Electric Dryer
Front loader dryer
Sounds like you have a broken belt. I had the same problem and replaced it myself. If you have someone handy at home, there are detailed instructions on the internet (just search) for replacing dryer belts for your model. That's what I did. A new belt costs about $13. If you need to call a service man in to replace, it might cost between $100 - $200.
Oct 27, 2008 | Dryers
LG Tromm DLE5977W Dryer about 1 1/2 yrs old. Running small load on normal and we heard a funny clunk noise and than the dryer shut off. When i went to look, power was still on with 20 min. left on timer....
3 screws on back of dryer to remove the top. Top slides back about 2 inches and lifts off. Dryer drum should have a thin drive belt around it. Pull on belt. If broken you will know. If loose, then it's off pulleys. Sounds like a broken belt. Check repairclinic.com or appliancepartspros.com for dyi videos on how to replace.
Mar 27, 2017 | LG Dryers
Install dryer belt on a lg
You will need to remove the front panel and the front drum support to get to the belt.
Mar 24, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
162 people viewed this question
Top Dryers Experts
