Question about Maytag Neptune MDE4000 Electric Dryer
Dryer taking a long time to dry. Is it normal for the tube in the back to have water in it? I know water has to go somewhere, is it normal for water to accumulate in the tube/?
  • 25 Answers
Sounds like the Vent hose is blocked.
Turn the Dryer on then go outside and check for air. If it's clogged ... Unplug the unit, take the hose off either at the dryer or outside vent, use something to probe the inside like a hanger , (put a small hook on the end) .. or completly remove the vent hose,take it outside ..see if you can see daylight , if not the unclog it.
BEFORE DOING ANY WORK ...DISCONNECT THE POWER
Posted on Oct 04, 2009
How to troubleshoot a whirlpool gas dryer
sounds like the duct work is plugged somewhere. or the blower fan has stopped. either way this is dangerous. please don't use till repaired. first make sure all the duct work and hoses for the exhaust are totally clear. they are known to get obstructed with lint. check the lint screen also it may look clean, but if you take it out to your sink and try to fill it with water, and it holds the water. that is your problem. to clean, scrub with detergent and brush till water runs easily thru it. finally if all that is checked out ok. it is time to take the dryer apart. (you can usually find procedure on line or you tube) and make sure the blower fan for the burner is working properly, and the bburner tube is also clear of any obstructions.
Oct 24, 2015 | Whirlpool Dryers
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
My dryer is new it's leaking water and not drying clothes it's bush tdv6w
you have a plugged vent from the wall somewhere to where it goes to the outside , the way to tell is to unhook the vent hose run dryer through normal cycle and see if cloths dry
Nov 24, 2013 | Dryers
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Jul 25, 2013 | Dryers
Dryer is heating but taking twice as long to dry clothes as it should. What could be the problem. Clothes that should take no longer than an hour is taking two hours or more.
Since you know for sure the dryer is heating, the problem most likely is lint in the dryer tube. You will have to remove the back panel of the dryer, and then remove the dryer tube. (Not the vent hose, although you may want to make sure that it and the dryer vent itself is not clogged). Remove the dryer filter and normally the 2 screws that hold the vent tube in. Remove the screws from the vent tube and get the lint out of the tube. There may also be lint around the fan. Get it all out. Be careful though, all the edges are sharp and will cut you if you slide your hand along it while "sweeping" out the lint.
Aug 20, 2009 | Dryers
Takes multiple cycles to dry normal load of clothes
Have the vent system from the back of the dryer to the outside of the house cleaned. If the dryer can't push air out, it can't bring air in, and the clothes won't dry. Another condition you might be seeing is moist lint developing around the gasket on the inside of the door. That's a sure sign the airstream is restricted somewhere.
Apr 25, 2009 | Dryers
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
A lot of moisture in the exhaust line of dryer...
thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Noisy dryer not drying clothes, water found in vent tube
You either have a restriction somewhere in the venting which you say you have already checked or maybe a bad blower (fan). it may be stripped off the shaft and not pulling any air through the machine. If you run the dryer with the hose removed at the back and it dries well you have a problem with your venting. If it still takes three cycles it's a problem with the dryer. Repair would probably run about $100-150
Oct 13, 2008 | Dryers
Maytag Neptune MDE4000 Electric Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
