Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
SimpleDrive 160 GB drive is recognized by XP, but cannot access. Have tried on 4 computers. Properties show 0 bytes size and 0 bytes free. Can't even Format Drive. This happened after interrupting an Autoplay that then seemed to hang and not exit. Any ideas?
    Guru:
  • 830 Answers
The drive was damaged during the interuption. This has happened to alot of my flash drives and there is not way to fix it. You can, however, replace the hard drive in the case. Open the case and you will see a small laptop hard drive (that's all it is), purchase a new replacement and throw it in there.
Posted on Oct 04, 2009
HP v218g PEN DRIVE 16 GB SHOWING 0 BYTES MEMORY
Click start control panel administrative tools computer management disk management right click on your drive select properties
click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Hope it helps.
Dec 02, 2012 | Electronics - Others
Unable to format usb stick
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Aug 05, 2012 | Dane-Elec DaneElec 4GB USB Drive Copper...
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Iam using windows-xp LG GSA H55N DVD witer does not recognize blank dvd's when i go yo properties it shows Type: CD drive File System: Unknown Used Space: 0 bytes Free Space: 0 bytes Capacity: 0 bytes i...
To solve this problem you need a third party burning software. Windows XP does not include the ability to properly recognize DVD's when you drag and drop and sees it as CDRW. When you bought your DVD, there may have been a disk with a version of Nero on it. It works well but there are also other third party software apps that will do as well. Even some free ones. Hope this helps.
Billybob115
Jan 08, 2009 | LG GSA-H55N DVD-RAM Burner
Unable to format 64 gb kingston pen drive
I am having 64 gb kingston pen drive.
But after formatting from command promt its file system is RAW an i cannot use the drive now.
Beacuse it is showing properties as 0 bytes.
The drive cannot be formatted.
Nov 20, 2008 | Computers & Internet
Unable to access external WD 500 Gb drive: "You need to format the disk"
It seems vista is the problem. On older operating systems the disk's work fine. My dis was formatted with vista and as a result showed exactly the same message when plugging it into a xp system. Back on the vista it works fine. The ntfs is native to win NT/xp there might have been changes in vista. Also do not use the firewire cabling, i had numerious problems until i reverted back to the usb.
Sep 19, 2008 | Western Digital My Book Essential Edition...
External 120GB passport read failure
I have the same problem - I did get to access the files one time, but not now.
I haven't tried all of these, but did try a couple (that was how I was able to access the data temporarily) - try a different USB slot in your computer, try a different USB cable, and/or try a plugging it into a different computer.
I think I have all of my info backed up, but not absolutely sure.
Good luck
Aug 11, 2008 | Western Digital Caviar SE 120 GB Hard...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
301 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
