Question about GE JBS55 Electric Kitchen Range
Oven won't heat up until circuit breaker is tripped.
    Sergeant:
  • 233 Answers
This is a very serious hazard if the circuit breaker trips just when the oven begins to heat up. The circuit breaker could have become weakened and needs to be replaced ASAP. Have an electrician check and replace.
The oven could have been placed on too small a circuit breaker OR the total number of appliances on that line has pushed the circuit breaker over it's limit. The Oven draws a huge current and may be the straw that broke the camels back.
Check to see what other appliances are shut down when the breaker trips. See if you can place some or all of these on another line.
Leaving the Oven on the one circuit breaker. This will hopefully prevent the overload situation that is occurring now.
If it still trips... get an electrician in there fast!
Hope this helps!
Posted on Oct 04, 2009
2 Suggested Answers
  • 81 Answers
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Tip
How to fix a Hotpoint fan oven that trips the circuit breaker or has no heat
In this video I dismantle, diagnose and fix a Hotpoint fan oven that was tripping out the earth leakage circuit breaker. It was the heater element which is easy and cheap to replace.
on Dec 02, 2015 | Hotpoint Ovens
No heat in oven
Check outlet voltage, a 240v circuit breaker can trip halfway and not be visibly tripped when looking at the breaker panel... 120v will operate the oven controls, but will not heat the elements...
Apr 23, 2016 | Ovens
My frigidaire range/oven model FEF365BWC is not working the surface and the oven are both not heating up. Everything other than that are working the oven light and the clock are working fine
You are not getting 240 volts to the heating elements. Go outside to the circuit breaker panel and find the circuit breaker for the range. It will be two breakers with their reset handles linked together so if one breaker trips so will the other. That's the part that isn't working correctly. Only one is tripped allowing the controls and lights to operate . Try manually resetting it. It most likely won't work, so you'll have to replace the circuit breaker.
Jan 22, 2016 | Frigidaire Kitchen Ranges
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
Oven heats up but wont get above 160 degrees
I assume you mean it trips the circuit breaker. If the circuit breaker is good, that means the heating coil is bad, and pulling too much electrical current. Sometimes circuit breakers fail, and trip at say 5 amps when rated at 15 amps. Have you electrician switch that breaker with another one and see if there is a difference. If not, it is a bad heating coil.
Oct 19, 2012 | Bosch HBN5046AUC Electric Single Oven
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 13, 2011 | Smeg Ovens
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
I have a Electrolux EXC643 Oven. When you turn on the oven, set to 200 deg C for example, the oven fan and light works, but the oven stay's cold. The circuit breaker has not been tripped, at any point....
circular element is almost certainly open circuit. often the breaker will trip when element goes faulty but not always. take rear cover off and check for continuity
Jul 08, 2008 | Electrolux Kitchen Ranges
GE JBS55 Electric Kitchen Range Logo
365 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
