Question about Cell Phones
I have blocked international calls and don't know my pin
I have a bt6600 phone. Need to unblock a number I a accidently blocked
Phone then. The very detailed instructions don't tell you how to unblock., but you could check the settings area as stated to see if the number is there.
Page 29
Block nuisance calls
The BT6600 blocks numbers in two separate ways
to help you avoid nuisance calls, firstly by type e.g
withheld or international and also by your choice of
specific numbers (you can store up to 100 numbers
of your own choice).
1. Select
Menu
, scroll
to
Call
Control
and
press
Select
2. Follow the instructions to set your PIN for the first
time and select
OK
, (see page 55).
3.
Incoming
calls
is displayed, press
Select
4. Press
to highlight
Block
calls
and press
Select
. You now have 2 choices:
i) To block calls by type, when
By call type
is
highlighted, press
Select
. Select
Blocked
or
Allowed
for each of the call types by highlighting
each one using
and
International
https://m.shop.bt.com/content/uni2/documentation/btj6/bt6600_user_guide.pdf
Feb 25, 2018 | Cell Phones
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
Pin blocked po ako d ko po alam ung puk code help me pls
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Jul 27, 2012 | Cell Phones
It says on the screen of the phone: PIN blocked. Enter Puk code:
Welcome to FixYa
Dear User
PUK code is related to your SIM card Provider .Contact them to get Code for FREE.Don't assume PUK code. Don't enter Wrong Code many times. SIM card will be Permanently damaged if you entered more than 3 or 10 times.
Let me know if you need further assistance..
Thanks for Connecting FixYa.
Jul 01, 2011 | Nokia Cell Phones
My nokia6630 lock code second is blocked and asking puk no which i don,t know
When a PIN code is entered wrongly three times, the phone line will be blocked. Irrespective of the owner, it is assumed that you are not the owner of the phone line when you enter your pin wrongly.
The blocked line at this point can still be unblocked and this is where the PUK code comes in. Once you enter the PUK code, your PIN code will be reset. You can then create a ne PIN code.
To get your PUK code, if your phone is using a SIM Card, Check the SIM card Pack and you will see your PUK code there. But if you don't have a SIM card pack, you can get the PUK code from your service provider.
Call the customer care line of your service provider using another phone, request for your PUK code and it will be given to you. Note that your service provider will ask you some few questions about your line in order to be sure you are the real owner.
Note that your service provider alone is the only one that can give you your PUK code because it's only your service provider that has it.
Regards.
Jun 29, 2011 | Nokia 6630 Handheld
PIN Blocked call customer care
You don't have another choice except contact the "Customer care" of your Service Operator (Network Operator). This happens when a user enters wrong PUK or PIN code for a specific number of times and the problem isn't with your phone but from the service operator's system which automatically block the sim service for security reason. Please read one of my tip related to PUK issue, you'll be able to understand the problem and what you'll need to do.
Click HERE to open the TIP.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 03, 2011 | Samsung Gravity SGH-T459 Cell Phone
My pins blocked i need puk code but i dont know what it is
Hi, here is what you need to know about PUK code;
I hope this is clear.
Regards.
Apr 24, 2011 | Nokia Cell Phones
Admiral dryer making clothes dirty and/or stained. Also, making inside of dryer, drum, door and vent, black. Taken dryer apart and cleaned it but found nothing that is leaking or broken.
Let's begin with the brass
plug with a little nylon pin
sticking out of it (see the
conversion kit picture above).
That white nylon pin is called
the blocking pin. Unscrew the
plug on the valve, called a
leak limiter, and replace it
with the new one that has the
blocking pin. This changes the
gas regulator pressure setting
for propane.Next, change the
orifice metering plug in the
burner. This controls the
amount of gas that enters the
combustion area.
One point of technique here.
Both the metering orifice and
the blocking pin plug are made
of brass and going into a
steel valve body. Brass is
softer than steel and will
make a gas-tight seal without
having to use gorilla force.
When you screw these brass
fittings in, don’t go nuclear,
Mar 11, 2010 | Dryers
My phone is locked i don,t know the pin sonnyericson w705
PIN CODE is SIM dependenet and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK, give the PIN 3 times wrongly and it asks for PUk,provide the PUK and set the new PIN..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 30, 2009 | Sony Ericsson Walkman W705 Cell Phone
Nokia 5130 pin blocked problem
Doesn't it ask u for a PUK code?....heres wat u gotta do....!
Call up Customer Care....n get it!
Btw, if u enter ur PUK wrong 3 times...ur sim will be permanently blocked!!....so be Careful!!
[ If ur a Vodafone customer, then u call up cust. care at 111....or, 9886098860...for any other fone!(toll free) ]
[ Its a Recorded msg mostly.... ]
Then, follow instructions and enter ur phone no.....They'll tell u ur PUK....
Enter ur PUK,
The fone then asks u to enter ur new PIN no. ......n confirm it!
If u wanna keep ur PIN code then it'll ask u for the new PIN dat u entered each time u switch on ur cell!!
if u don wanna keep it, then go to Menu>Settings>n to whereva u disable ur PIN code....n try not to 4get ur PIN code.....
If u can't remember it ....then keep it as four zeroes ( 0000 ).....this is usually the initial PIN no. when u get a new phone!
Sep 19, 2009 | Nokia 5310 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
