Question about Roper RAS6233KQ Top Load Washer
I have a roper RAS6233KQ that will not fill with water, but once i manually load water it works, what part do I need to replace?
    Top Expert:
  • Roper Master
  • 76,070 Answers
Start by checking and replacing the inlet water valve, u do't say if both hot and cold water work or don't work, so u haven't supplied all the needed info to make a correct diagnosis, switch to hot and cold, if neither work then the control board (CCU) has failed and you will need to replace that central control circuit board.
Posted on Oct 04, 2009
Hot water doesn't turn on to fill the washer
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 16, 2011 | Roper RAS6233KQ Top Load Washer
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
My top load kenmore washer filled with water and just stopped
Try tightening the screws on the lid hinges. This should re-engage your lid switch. If it doesn't then you may need to replace the lid switch.. Hope this helps... Bill
Jun 04, 2009 | Roper RAS6233KQ Top Load Washer
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
My Roper won't fill with water.
you need to replace the water inlet valve on the washer that the hoses go on,it is stuck closed,have you tryed hot water only to see if it comes out?the valve has a hot and cold water supply valve,you can get one by going to sears .com click on parts out in your model number and order your part,let me know if you want to try it and i will tell you how to get into the cabinet-mike
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
Jul 21, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
13 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
