Question about Compaq ~:~ HEWLETT PACKARD COMPANY ~:~ LaserJet CP3505N Color Printer
PSC1410 All-in-one Paper jammed, now computer will not respond to computer.
There is no paper Jam. on the control panel the jam light remains on. There is no connection between the printer and the computer. But the cable is ok, because it works on the same other printer.
Remove side & back covers before starts is activity:1. Check whether printer initializing after powering on? If the error appearing after initializing check is there any paper jammed under the registration assm area.
2. If the error showing straight away after power on, check paper jam in duplex unit. check paper out sensor & sensor flag located in fuser assembly . Fuser assm located at back side of the printer.
3. Remove and refix all connectors on DC controller ( you can observe the connector below user assembly..
Jun 13, 2012 | HP LaserJet P2015 Printer
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Printer is clear of paper jam but my computer screen says theres a paper jam. printer does not respond
There might be a problem in the back of the printer that you cannot see. HP support instructions for clearing a paper jam for this model are here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=441125&lang=en
Dec 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
PAPER JAM
hi!
try to reinstall your printer driver and then
clean the roler and check the port of your printer
Sep 11, 2008 | HP Deskjet D2360 InkJet Printer
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
qwester
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
My hp psc1410 printer
yes by using windows gallery.open the windows gallery then click file - click import scanner - then select your printer model.scan it
Jul 18, 2008 | HP PSC1410 Printer
Paper Jam
Remove all the paper from the paper tray so that nothing gets sucked up in there while you're working. Hit the cancel button a few times until the screen clears itself and goes back to the "Print", "Copy", "Scan" option screen.
On your computer, if the printer option screen is up (depending on what kind of computer you have, a small screen might pop up to tell you the print progress), hit cancel or clear on any of the lines that say "Paper jam", if there are any.
The next time you print something, only put as many pieces of paper in the feed as you need to print. This should eliminate a lot of the chance of actually getting a paper jam.
Please respond again if this didn't help. I'm not sitting in front of my own computer right now, so I might not be following the same steps that I usually take.
Feb 02, 2008 | HP Photosmart C4280 Aio Printer
Why won't my printer respond to my command?
May be the small paper pieces hav jammed inside if not do this
switch off the printer and disconnect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Dec 28, 2007 | HP Photosmart C3180 All-In-One InkJet...
Compaq ~:~ HEWLETT PACKARD COMPANY ~:~ LaserJet CP3505N Color Printer Logo
14 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Pam Kelly Andrews
Pam Kelly Andrews
Level 1 Expert
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
