Question about Fuji FinePix A350 Digital Camera
Help My Fuji FinePix A350 has styopped turning on. The silver thing that is in the battery holder fell out.. i put it back in. Green light only comes on for split second. Now i would like my internal memory pictures off of the camera somehow. Can i do it?
Benimur
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
SOURCE: Fuji FinePix 4700 zoom Camera
memory card only. The "smart media" cards are very difficult to find now, as there are no current models which still use that type of card.
Posted on Jan 23, 2008
  • 203 Answers
SOURCE: Fuji FinePix A350; Can not
i reviewed the manuel and it looks like you can only output d and t on playback mode to a printer to imprint on -date and time stamp on actual pic is not a feature on a lot of models-canon still does it but you need to put camera in postcard size pic mode to do it
Posted on Aug 18, 2008
  • 3 Answers
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: finepix a610 fuji -howdo i
The other answer doesn't work. I tried it. Okay, this is straight from the manual AND I tried it and it worked:
Press Play/playback to view pics.
Press Menu. Under playback menu, scroll down to COPY. Hit OK. Press OK for or scroll to & then hit OK for "Internal Memory -> Card" and press OK. Press Frame or All Frames. Press OK. Done! :)
God Bless. John 3:16
Posted on Mar 09, 2010
if you view horizontal lines - replacement LCD
May 20, 2009 | Fuji FinePix A350 Digital Camera
FinePix A350 Power Button stays down after being starting camera
This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
Mar 23, 2008 | Fuji FinePix A350 Digital Camera
Fuji finepix a350 zoom error
This problem is quite common with this camera. Try pulling the lens out gently all the way till the lens cover opens. Then you twist it gently till you hear a click and it should be fixed. Let me know how it goes.
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Fujifilm finepix a350
This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
They want to swap it with a E500.
Both of these replacements are less of a camera then the A350.
If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
Dec 14, 2007 | Fuji FinePix A350 Digital Camera
FUJI A350
dont know if this helps but i had a problem that was similar, turns out card is not compatible, check here to see if you have a compatible card
http://www.fujifilm.com/products/digital_cameras/accessories/card/index.html#compati
Nov 26, 2007 | Fuji FinePix A350 Digital Camera
Fuji digital camera
Nothing in the manual refers to this problem. Send back to Fuji if still in warranty.
Nov 16, 2007 | Fuji FinePix A350 Digital Camera
FUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Nov 13, 2007 | Fuji FinePix A360 Digital Camera
Help
Time for a new camera.
Jul 20, 2007 | Fuji FinePix A360 Digital Camera
Camera will not turn on.
Check the manual for indications of error. Look for a reset to factory settings option. Switch off and remove batteries Take the memory card out and carefully cleane the contacts, now wrap a piece of paper atround the card in such a way that you have a frip on the paper an insert it and work it up and down thus polishing the chamber contacts. No joy? Contact Fuji Technical help team.
Jun 11, 2007 | Fuji FinePix A350 Digital Camera
Fuji FinePix A350 Digital Camera Logo
16 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
