Question about Samsung Digimax V4 Digital Camera
It stays on standby and does not want to take pictures. if you turn it to another setting it switches off
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
TELEVISION IS IN STANDBY WONT SWITCH ON TO PICTURE
First is the set should have a 1 year parts and or labor warranty--second: in order to offer advice or give help I need to know brand and model number.
Dec 06, 2012 | Televison & Video
Tv turn off after switching on from standby mode
THE set has a standby power supply that runs 7/24 if set is plugged in--if that does not have bad caps etc it switches the main supply on and voltages etc come on and stay on CAN BE CHECKED WITH A METER OR if something is pulling voltages down it has to be searched for.
Mar 27, 2012 | LG Televison & Video
I cannot turn TV off from remote. It makes the picture go out but red light is still on. Have to unplug the TV to turn it all the way off.
red light stays on because tv is in standby mode when switched off by the remote, should be an on/off switch on the tv body somewhere
Sep 10, 2011 | Hitachi Televison & Video
TV won't stay on. Standby light flashes 5-10 seconds then shuts off. Just before this happened - it turned on , had good sound but the picture never lit up. Now it won't even turn on. I've...
Hello
Blinking of standby light in Sony sets are fault indication. You just count the exact number of blinks occur at on instance, say, after you switch On and OFF by its front panel power switch, not by remote control hanset. Just count it atleast 4 times, count it keenly and inform it to me, and let me reach to the nearest falult point; or sometimes to the exact point. OK.
Dec 06, 2010 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
My TV will turn on and stay on standby. You can
the video IC is broke so... buy a new and change it
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light stays on
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
Samsung Digimax V4 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
