Question about Hoover Vacuums
Detergent bottle keeps falling off, wont stay put and clean water isn't emptying at all
  • 294 Answers
The tank assembly needs to be replaced. Keep your tank handle. The other problem is your water not dispensing. There are electric solenoids and a pump that control dispensing soap and water. Take it to a repair shop for complete diagnosis before you replace the tank. The new tank is better, both soap and water tanks are in one assembly
Posted on Oct 11, 2009
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Tip
No water/detergent coming out of vac/cleaner
If you are having any trouble getting the detergent or water to come out of your vac then this could be down to one of a couple of things.
Now if the vac is new then the chances are you have not held the button down for long enough to allow the water/detergent to flow through the vac so hold the button down for a couple of minutes and it will eventually come out.
Now if you have used this before and it is no longer working then you have got a blockage problem.
The first thing you need to do is tip the vac up on its back and have a good look at where the water/detergent comes out of, you should see several little jets running along the bottom of the vac right at the front, now what you need to do is get a long pin and give all of these little jets a good poke with a long needle make sure you do this to all of the jets.
Once you have done this sit it back up right and give it a try, you may need to hold the trigger down for 2 or 3 min to let the water/detergent work its way through the vac.
If how ever it still dont work then empty the detergent/water bottle and fill it with hot but not boiling water and add a couple of table spoons of salt now put the bottle back on the vac and leave it for 3 or 4 min then switch is on and hold the button down again for 2 or 3min. Now the hot water and the salt should have broke down any build up of gel that the detergent has turned into over time.
Repeat this process 2 or 3 times to give it chance to work its way around the vac.
After doing this check the jets again and poke with a needle as the chances are the blockage has now moved and is by the jets, now give it another try.
If it still dont work then the blockage must be quite bad what you now need to do is unplug the vac and lie it on its back now if you have a good look at where the jets are you will see several screws holding the bottom part of the vac to the top part.
All you need to do is undo these screws and remember where each screw came from in case they are different sizes now once you have the screws out the bottom should come away form the top, be carefull here as the hose that goes to the jets will need pulling off once you have pulled this off the bottom should come away no problems.
Now with the bottom off you can follow the way the water/detergent goes so if you follow it from the jets you should see the hose that carries the water/detergent, so what you now need to do is follow this hose and keep giving it a good squeeze where ever you see water backed up keep squeezing it all the way along as far as you can.
You may see the blockage if you do just give it a good squeeze where the blockage is to break up the gel blockage, if you see no blockage then keep reading on. if how ever you have found the blockage then make sure you squeeze it out as much as you can .
Now put everything back together, if you found the blockage you should find that filling the water/detergent bottle with hot but not boiling water should now get you up and running just keep and eye on the jets until the blockage you found has past out the jets.
Now if you never found the blockage empty the water/detergent bottle and check where the water comes out of the bottle into the vac you should be abe to press it and see if the water flow freely out of the bottle. if it does then you need to check the part of the vac where this bottle attaches to, their should be some sort of filter where this bottle fits so have a look their and clean with a pin if blocked.
If you find no blockage then try again with the hot water to rule out 100% blockage being the problem. if you have checked and their is no blockage then this would indicate a problem with the pump or a blockage in the pump, now as the pump is not a serviceable part you cant take it apart and clean it so the only option you have is keep trying with hot water or replace pump( check any warranty before you do any work yourself)
The hot salty water should work but make take several tries until it breaks down the gel build up.
Now what they should have told you when you purchased your machine is that after every use empty the detergent bottle and fill with clean warm water and then let this run through your cleaner, you need to do this as if you leave the detergent in the bottle and leave it in the pipes inside the vac then what happens is that over time the detergent turns to a gel so making sure the detergent is gone will guarantee the vac will work the next time you want to use it
on Mar 26, 2010 | Vacuums
Older style ....no water coming out...did clean all hoses...
Courtesy- Pauldonp
Jun 26, 2010 | Vacuums
No spray detergent comming out of bissell carpet cleaner
hi, the main reason you have no spray coming out is due to a blockage, if its new and has not been used then you need to hold the button down for 2 or 3 min before detergent comes out, how ever if you have used this before then the chances are its blocked.
The most likely place for blockage is where the water comes out of the jets at the bottom at the front so tip the vac up and give these little holes a clean with a pin or something else you can fit into the hole to remove the build up of gel caused by detergent build up.
If after doing this it still dont work then empty the detergent bottle and fill with hot but not boiling salty water and leave it in the vac for about 10 min then switch on and hold button down for couple of minutes to see if this has then cleared the blockage.
If after doing this their is still no water coming out then your going to need to take the bottom of the vac off and follow the hose the water comes out of adn check for any blockage once you find the blockage squeeze the pipe at the blockage and this should then free it up.
Now what they dont tell you when you buy these but what they should tell you is that after every use empty the detergent bottle and fill with warm clean water and then press the button and let this water flow through the vac for a couple of minutes doing this will ensure you have no more blockages.
Let me know how you get on or if you need further assistance ok
Mar 26, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have a bissell 9400-E and it doesnt spray cleaning fluid from underneath the machine, the hand tool works. have trie purging the machine with hot water in fluid tank and continuously hollding button with...
This may be caused because the pump belt has stretched or broken or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime.
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Nov 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit sprays for the first few seconds after I turn the unit on and then stops spraying any water or solution. I turn it off, wait a few minutes and the same thing happens. What is going on and how...
This sounds as though the pump belt is slipping. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Pump may have lost prime. Check all the fluid tubes / hoses for leaks or blockage (see below).
Oct 30, 2009 | Bissell 7901-R Clearview Proheat Plus...
Water doesn't come out
hi this is very common problem what you need to do is lie the vac on its side then where the water comes out of the little jets at the bottom of the vac these are usually blocked and will need cleaning using a pin to poke through should solve the problem.
If the blockage isnt their then you need to undo the screws on the bottom and keep working your way along the detergent/water lines and keep cleaning them out you will find a blockage along the way.
Try using hot water first empty out all the detergent and just use very hot water (not boiling it will melt the pipes but hot water nearly boiling will do) Keep runnig hot water through the system by pressing the button you press for it to spray the water do this for about 15 min and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage.
What happens is when the vac is standing for a while the detergent turns to a gell causing a blockage.
What they dont tell you in the user guide and what they should tell you is that after every use empty out all the detergent and then run warm water through the vac for about 15 min doing this will ensure you have all the detergent out and will make sure you have no further blockage.
Everyone who buys one of these types of cleaners has this same problem so you are not alone.
Oct 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=641300
Generic problem for all Vacuums
Posted by w_brennan on Jun 02, 2008
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a problem with the bottle you fill with detergent ex: this bottle is separate from the main clean water tank. THE PROBLEM: The little plastic part that goes in the bottom of the bottle has an "O" ring ex: cone shaped with a spring.....it keeps falling out. Can you supply a part number for this component? The bottle has a number ex:36778-002. Thanks...Linda (504) 888-2120.
E-mail address: w_brennan@bellsouth.net
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hover SteamVac V2 with Auto Rinse feature. I would suggest because the model 3 and the serial 3 have been worn of the machine to contact your local vac dealer in your area and or the Hoover Factory Service or the Hoover Website for the Factory Model #, but the part that you are requesting is not very expensive and can be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Shampoo /cleaning agent
Could be the cap and valve at the bottom of the detergent bottle may need to be replaced. Is the water spraying out ok? If it is, then I would suspect the detergent bottle.
Feb 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
83 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
