My Maytag stinks! Literally! It smells like mold or a cesspool. What could be causing this? Is there something i should be cleaning that I'm not that could be causing this odor?
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
This is normally a build up of dirt within drum....You could try boil wash on its own or buy a cleaning agent for that purpose/ also check sink is clean @ drain hose end. this can cause problems..Happy wash days....Good luck
Posted on Oct 04, 2009
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
Aug 15, 2014 | Kenmore Elite HE5t Washer
KITCHENAID W10311123B STINKS
use the following product. God bless you
Affresh
HE Washer Cleaner - Recommended by Maytag and Whirlpool
Odor Remover and Smell Blocker .Oxigenated cleaning action lifts away the Stinky,smell odors in your HE washing Machine.
Jul 29, 2013 | Washing Machines
Where is the filter on the series 70 washer? my washer has a stinky smell and someone suggested it may be a filter that needs to be cleaned.
clean the door boot carefully with bleach if mold grows in the lower door drain holes it will mold and stink,you will see black spots on the boot,thats mold
Sep 11, 2011 | Kenmore 24032\24036 Top Load Washer
It has a horrible odor. Also the little door on the left bottom front of the machine holds water. How do you keep the water (stinking) from standing in that area?
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
Mar 12, 2011 | LG WM2233H Front Load Stacked Washer /...
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Frigidaire Affinity front loader smells like mold
have you cleaned the main waste pipe as this surpisingly enough gathers a lot of gunk and in warm weather makes it smell,i say this cus we expeirieced this and i replaced rather than cleaned the waste pipe,worth a try it worked for me,rgds paul
Jul 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer stinks - smells like mold or mildew
You have to kill the mold. To do that mix one cup of clorox liquid bleach into one quart of water and wipe all aroung the rubber. Let it dry and do it again. That will solve your problem
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Mold on gasket
The mold is common with the front loaders all you can do about the mold is wipe out the water that is in the gasket after a wash and leave the door open. DO NOT TRY TO CLEAN WITH BLEACH. The bleach will make the gasket weak and cause it to rip and then cause a leak.
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Maytag washer purchased in 2000
Hi, The problem you are having is from mold and mildew. This is caused due to it being an HE washer (high efficiency). They use very little water and have a super tight sealing system. Maytag came up with a solution for it. Its called Affresh. It is an oxygenating tablet that literally eats the mold and mildrew. Its a good product. You have to use it on a regular basis to keep the stink and mildew away. You can get it on line at www.affresh.com.
Nov 09, 2007 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
