Question about Ricoh CL4000DN Laser Printer
Envelope gets all creased when printing - Ricoh CL4000DN Laser Printer
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
Dell 5310n knocking noise when printing envelopes
This is a good thing. The 'knocking' noise is actually called a "Thumper". It's purpose is to get the air out of the envelope before it hits the fuser. Air in the envelope typically leads to creases on the envelope itself.
Feb 25, 2009 | Dell 5310n Laser Printer
Envelopes
Make sure the paper type for the tray from which you print envelope is set to Envelope. If the printer doesn't know that an envelope is being printed, it will not turn on the "Envelope Enhance" feature. The Envelope Enhance feature pumps air out of the envelope before it enters the fuser and can prevent creasing in the envelope. However, keep in mind that any envelopes larger than a US Size 10 will most likely crinkle, with or without the Envelope Enhance
Dec 19, 2008 | Lexmark T644 Laser Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Ricoh CL4000DN Laser Printer Logo
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
