Question about Frigidaire FGQ1442ES Gas Dryer
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
IGNITOR DOESNOT HEAT DRYER UP. NO FLAMES. LIGHTS UP LIKE ORANGE FOR FEW SECONDSS AND TURNS OFF. NO HEAT. KELVINATOR GAS DRYER. MODEL MDG216RBW0R0
  • 464 Answers
The ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Posted on Oct 04, 2009
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Turns on but. Will not heat upb
The areas that come to mind is the ignitor and/or sensor has gone bad The most unlikely is the gas valve but it is a possibility. I check for a thermal fuse on your model It does not come with one. That eliminated another cause.
Attached is a picture for reference.
When the dryer is turned on, the ignitor ( #74) will start to glow and in a few seconds to a bright orange color. The sensor ( #79) which is located on the outside of the flame tube, detects the heat intensity from the ignitor. Once the ignitor has reached its limit when operating correctly, the sensor will give a signal for the gas valve to open and release gas through the burner where the ignitor will light the gas. This process repeats several times when drying a load.
Defective ignitors will either have no glow or the will glow a little bit.
Hope this helps you out.
Always you caution when working on appliances.
Nov 16, 2010 | Frigidaire GLGQ642A Gas Dryer
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
Whrilepool gas dryer wont heat but runs.
First, Remove small plastic tab on front panel of dryer lower below the door on left. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Sep 20, 2009 | Whirlpool LGR5636L Gas Dryer
Gas Dryer model 110-77974110
the coils on your gas valve are going out , this is why it will work at first and stop , the coils heat up and wont open the valve again after they are heated.
I thought they were some what cheaper than they are now but still not too bad. you can try this part number search on ebay for the best price I can find.
279137 coil kit
Phil
Jun 11, 2009 | Kenmore 74602 Gas Dryer
Frigidaire Gas Dryer not heating up, Model FSG447GHS0
check vent and vent ehaust tube for blockages..
Dec 29, 2008 | Dryers
Lighting the pilot
there is no flame type pilot. when you turn on the dryer remove small cover on lower left front panel to view if you see a orange glow, which means your ignitor is getting power listen for 1ckick sound and then a second after the ing glows. there a few things that could be bad ignitor. soleinods on the gas valve or a bad thermal fuse
Dec 19, 2008 | AEG T57800 Electric Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
188 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
