Question about Freezers
BEKO fridge freezer STOPPED FREEZING
I HAVE A BEKO FRIDGE FREEZER MODEL CDA543FS . THE FREEZER PART HAS STOPPED FREEZING ALL MY FOOD IS GOING SOFT. THE FAN IS BLOWING A COOL BREEZE INTO THE FREEZER. ANOTHER THING I HAVE NOTICED BUT NOT SURE IF HAS ANYTHING TO DO WITH THIS PROBLEM IS ON THE BACK OF THE FREEZER BEHIND THE METAL BARS WHICH ARE USUALLY HOT BUT SEEM COLD TO THE TOUCH IS A SMALL BLACK TUBE , AT THE BOTTOM OF THIS TUBE IT DOESNT SEEM TO BE CONECTED TO ANYTHING IM WONDERING IF THIS COULD BE CAUSING THE PROBLEM?
SOURCE: samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Posted on Sep 06, 2009
SOURCE: My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Posted on Aug 26, 2008
duby1990
  • 370 Answers
SOURCE: freezer stopped freezing
If you checked the fan and for ice on the back wall (for defrost problem) Then you most likely are low on freon or you have a bad compressor. Check to see if the compressor is running (IF scorching hot its bad too) . Next check to see if the coils under the unit are hot. They should be so hot you cant hold onto them. Just touch for a second. If they are just warm, then you are low in freon.
Posted on Nov 19, 2008
  • 20 Answers
SOURCE: Kelvinator chest freezer not freezing
SUM HUSBAND. call the handyman N-E-WAY
Posted on Jun 09, 2009
SOURCE: I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Posted on Jun 24, 2009
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Freezers Logo
124 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
