Harmon Kardon AVR220 Humming noise
My reciever has a humming noise (much louder when unit is firt turned on, then nearly goes away). The humming does not get louder with increase in volume. A few years ago I was dumn and had it wedge in-between two shelves, it would turn off if we had it on for long periods(obviously it was over-heating, but I wasn't smart enough to figure this out before it caused this problem). Am I out of luck or is there a repair possible? Which part of a recieve would a humming noise be coming from?
  • 37 Answers
The most frequent cause of a "humming noise" in electrical components is called a "ground loop". If you want an indebth discussion of just what this is, you may go to this link:
http://en.wikipedia.org/wiki/Ground_loop_(electricity)
If, on the other hand, all you want to do is stop the humming, you may be interested in the discussion here:
http://forum.ecoustics.com/bbs/messages/1/130397.html#
No need for me to reiterate all that is said in the above discusssion. Try all of the suggestions made. Good luck.
FixYa is having some problems with internet links so you may need to copy and paste the links into your browser.
Hope this helps.
Posted on Oct 04, 2009
My Dodge Grand Caravan is making a humming noise as you accelerate, while turning left it stops but gets worse while turning right. I replaced the left front wheel hub and no improvement, I need help
if hub bearing replacement did not fix the noise
when noises are on left and right turns
that has CV joints /drive shafts
would say they are the issue
replace both sides
and replace the left hand hub bearing at the same time
Oct 20, 2016 | Dodge Caravan Cars & Trucks
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Low pitched humming
When it makes the noise and you able to do this try turning to the right and to the left. If the noise changes or goes away than your on the right track with a bad wheel bearing.
Dec 27, 2012 | 1998 Pontiac Grand Prix
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Humming noise coming from receiver, repair or replace
Humming noise is usually a sign of a roving fan and this humming noise comes when the fan is moving with difficulty all you have to do is get a repair personnel to service the unit and is not enough to get the unit replaced.
Hope this solution has been helpful?
Happy new year
Jan 01, 2011 | Harman Kardon AVR 100
There is a humming sound coming from the front end of my 1999 oldmobile alero. Only happens when the car is moving. I dont hear itat idle or even when pushing the gas at idle. could it be my transmission...
Hello! If the humming noise is speed related(gets louder as vehicle speed increases)check front wheel bearings. If the noise goes away when turning one way or the other then it will most likely be in the front wheel bearing. If you turn the wheel(while moving)to the right and the noise goes away it is on the right side. If you turn the wheel to the left and the noise goes away its on the left side. Hope this information helps!
Sep 13, 2009 | 1999 Oldsmobile Alero
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Jan 07, 2009 | Harman Kardon AVR 225 Receiver
Humming noise in Harmon Kardon AVR 110
on what cd dvd ? cheak cable 1st rca swap out
Jan 29, 2008 | Audio Players & Recorders
143 people viewed this question
 Grubhead
Grubhead
