Model#CT27SC14J Wont power up
Sharp tv 70 inch wont turn on blinking 5 times fast 2 times slow
Which model do you have because the blink code differs from model to model. Did you try a hard reset? Meaning, unplug the unit, wait a minute or two, then holding the power switch down, plug the unit back in while still holding the power switch down. When it comes back on, release the button.
Jul 14, 2015 | Sharp Televison & Video
My hp model, hp pavilion rt3290, red wont work power button is on caps lock flashes n thats it
Try this "wrapping the laptop with a fleece blanket" according to this forum it is a known problem with graphics adaptor.
Laptop not booting and CAPS lock blinking
Feb 14, 2015 | HP Computers & Internet
I lost my power cord to asus laptop, and my laptop wont charge with other power cords, so do I need to just buy a new power cord? or because it wont power up is there something wrong with my laptop?
You will need to buy another power cord for the exact model of your laptop. You can either find it in local computer stores, or you can search for it on ebay.com (usually search by laptop make & model, & usually buy from a top seller).
Dec 11, 2010 | ASUS Computers & Internet
Battery works but wont charge battery wont run off ac power supply but ac power supply is good will run my other laptop
Hello, you don't mention the model number, but there was an issue with the power connector mounted on the mother board of certain Dell laptops causing the type of problem you've got. Dell refused to address the issue until a group of users in the USA threatened a class action against the company, then Dell agreed to repair all affected laptops and extend the warranties. It's possible that yours is the same problem. Unfortunately, if you're NOT in the USA you wont get it remedied for free. As you don't state the model, I can only speculate that you're having the same problem, but if you google your model type, you may find some interesting reading. And perhaps you're not alone.
Regards,
nicam49
Oct 30, 2010 | Dell POWER SUPPLY Power Supply
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
PANASONIC CT27SC14J OWNERS MANUAL
Click HERE to download user manual of Panasonic CT27SC14
Mar 18, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
