Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The glass top on my Spectra feels smooth but the burner area is turning black. How can I return it to it's spectuled gray?
    President:
  • 1,304 Answers
If its a build up you can use a razor scaper after you warm it up just a bit
'warm the burner do not get it hot
then scrub the dust with a non abrasive pad/sponge
with a chem. called cryramabrite
Posted on Oct 04, 2009
Spectra range. Both large burners diagonal across from each other have stopped working. Is this fixable. Other burners OK.
yes it is is this glass top type ? very easy to work on and get parts for , first thing unplug unit from walll, there are two screws near the front of the oven.to the left and to the right of the oven.near the top front . once you remove the screws lift the top up and support it with something look at all the wires and you will see one that has been burned , the only wire you can use inside of this area is what they call glass wire , so it will take the heat . I am almost positive this is just a burned wire , replace the burned wire with glass wire and you should be all set, keeping in mind move the wires away from the burners this time so it wont happen again
Jul 26, 2011 | General Electric Kitchen Ranges
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
Stovetop ceramic burner turned black and smooth
Do you have a proper ceramic top scraper ?, if not buy one (about £10 UK)
Get a bottle of cream cleanser and a plastic type pan scrubber
Soak the area with warm water , pour on some cream cleanser and work it in with the scrubber , when you have formed a nice creamy froth use the scraper to get underneath the scorching
It is a lot of hard work but it does come off
Sep 28, 2009 | GE Kitchen Ranges
Replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Jan 05, 2009 | GE Profile Spectra JBP90SFSS Electric...
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cracked glass top
Your crack was most likely cause by a flaw in the glass top. Most GE smooth-top ranges (espesially if manufactured prior to 1/1/06) have a five year warranty covering this type of failure. The labor is not covered after the first year. Check the back pages of your use and care book for warranty info on your model. I'd advise against continued use of the cook top with a crack, as spills can get to components and cause further damage.
Aug 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
Glass top stove
you can try a flat blade rasor blade, cerama brite smooth top cleaner and some elbow grease
Feb 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
Replce smooth glass cook top
Id be glad to help from my end. I would reccommend a live chat session while you are working on it so i can give you expert pointers.
Nov 24, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
Glass top turned black
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Mar 17, 2007 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
