Question about Kenmore 24032\24036 Top Load Washer
When my machine spins out it makes a raspping noise then makes a klunking noise. can you help me?
  • 909 Answers
Could be either something inside the outer drum or the bearings are breaking down. open the door and wobble the drum side to side and top to bottom(push the top while pulling the bottom) and if it moves alot (more than a few millimetres) then the bearings are on their way out.
Posted on Oct 04, 2009
Out of balance when spin starts
Hi dear. Your machine needs new shock absorbers and drum tension springs replacement. I can advise to contact your local Miele center. Thanks.
Apr 01, 2016 | Miele Washing Machines
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
Klunking noise and banging at spin cycle. balance ok
Check your suspension supports, when empty move the tub around it should re-center with force like it fights you to be in the center,
Sep 18, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Makes a rasping or grating sound whilst spinning. Does it need a grease? 6years old. Model no.wfl2400
one of your drum wheels apear to be making noise, they do use barrens try alittle inside see if it helps, plus one wheel could be bad dont use too mutch plus check your belt for wear and drum...
Apr 13, 2011 | Bosch Classixx WFL 2462 Front Load Washer
2002 Yamaha r1 when riding the bike it makes a rasping chain like noise
Hi, Tom for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/249799-clutch-noise.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/86223-clutch-noise-when-idling-may-normal.html
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 29, 2010 | 2001 Yamaha YZF-R1
I have a KENMORE WASHER MODEL 11020894990.The slow spin comes on and works fine but when it stops to begin the faster spin it makes a klunk klunk noise and will not spin.
Well the klunk-klunk is the Break grabbing, to stop it, as it is detecting, what it thinks, is some sort of Unbalance or Overload, or detecting a motor fault, etc, real or not, and is shutting itself down because of this.
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Makes klunking noises during the wash cycle only. gets worse with heavier loads but klunks on lighter loads too. what is this?
there are leveling feet on the front of the washer ..make sure the washer is level...they should turn like a screw
Nov 08, 2009 | Maytag HAV2558 Top Load Washer
When in spin made loud klunking and screaching noise. now will not work in spin cycle without making loud klunking noise
Pull off the bottom panel, (three 1/4" screws along bottom). Check for chunks of concrete hanging down, or in the bottom pan. I have seen the lower front counter-weights on the HE2 break off several times. If not, reach in and give the basket a hard spin by hand, if you hear clunking or grinding, or the basket feels loose, you have a bad basket brace (usually caused by slop in the rear bearing). You would need to replace the rear shell (comes with a pre-installed bearing) and the basket. Depending on age, these parts may be in warranty, check your manual.
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
When I start dryer makes a loud hollowing noice and smells burnt.
hi dcimproveman,most common noise on whirlpool/kenmore dryers are the rollers.i would describe that noise as a klunk,klunk.klunk.what you do is unplug unit,pop the top,take off the frount,loose belt and remove drum.takes me less than 5 min.clean inspect/oil /no wd-40 replace worn parts as needed.if you get stuck,just send an email
Jan 01, 2009 | Kenmore 62602 Electric Dryer
I think my washing machine just died!!!
The transmission could well have caused the failure but the smoke was almost certainly from the drive motor.
The cost of replacing them both is probably prohibitive.
Unless you are really into preserving the environment (and your machine) it may be time to retire it.
I don't know where you are but I would estimate the cost of the transmission at $120-150 US and the motor at $60-100 only for parts.
With the growing complexity of many machines, I tend to stick with those using older technology and keep my fingers crossed that they have not cheapened the quality too much.
As we equipped a new house 3 years ago, I did a lot of research and found essentially no machine that was 'bullet-proof.'
We finally bought Roper machines and have not had any complaints to date but have a small household so not much stress on the machines.
Roper has been owned by Whirlpool for years but my experience with direct Whirlpool branded machines really stinks; refrigerator died due to a low-voltage condition that occurred while we were gone requiring a new comperessor, washing machine thatate its transmission in < 3 years, etc.
All were purchased new.
Jun 21, 2008 | Crosley CAWC529JQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
53 people viewed this question
fordexpert
Mike Squire
Robert Rankin
