Question about Mr. Coffee TFTX85 Coffee Maker
Coffee won't brew - lights turn on - clock works - clicks little.
This website says clean per your instruction manual - probably 2 years old - no manual - any ideas how to clean - or just pitch and buy new one??
My coffee maker will not brew a complete pot of coffee. The maker shuts off and we have to stand next to it and waste time turning the button back on over and over in order to get a full pot of coffee. The thing is, I have tried vinegar more than once and that has not rectified the situation. This is the second coffee maker by Mr Coffee that this has happened to. Coffee makers used to last for years and year, not anymore. I am dissapointed in this product.
Posted on Oct 29, 2010
My 4 cup Mr. Coffee also had this problem. The machine would not turn on. I filled the carafe with 5 cups of white vinegar and held the start button down for 2-3 minutes until coffee make started to heat and flush vinegar through the machine. It contained all sorts of mineral deposits. I repeated this a couple of times followed by a clear water flush to remove vinegar. It now works fine and I will repeat this every month or so as I do use hard water. It saved by Mr. Coffee from trash!!
Posted on Jan 31, 2010
    Sergeant:
  • 233 Answers
2 years old I would pitch and buy a new one.
Cleaning generally won't help a machine that does not work.
Heating element has probably burned out.
(I am not talking about the heating pad for the carafe!)
For future reference for all the coffee drinkers out there:
Simple quick way to clean a drip coffee maker is use Vinegar.
Let it brew through the system as you would water.
Discard and run fresh water through the system to clear out the vinegar residue left behind. (Make SURE the system has cooled first before running the fresh water through!)
For those that have hard water and the coffee tastes funny.
Try a small pinch of salt in the filter basket ON top of the coffee grounds. This will soften the water and hopefully take the bitter taste away.
Guess it is possible large enough calcium deposits could block the hole in the holding tank to prevent the water from percolating to the filter basket. You may wish to check this before tossing. Last minute thought before pushing the post button.
Posted on Oct 04, 2009
Red ! flash frequently
So many faults can cause this problem.
The most common is the brew unit requires cleaning and regreasing as per the instruction manual.
Jan 25, 2013 | Saeco Odea Giro Espresso Maker -...
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
When brewing the coffee at times the water stays and almost overflows where the filter and coffee is rather than brewing properly- what could this be and how to fix it?
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Aug 13, 2009 | Cuisinart DCC-1200 Coffee Maker
My grind and brew turns itself off in the middle of brew cycle
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Re: no coffee comes out after the grinding and loading stages!
Sounds like your coffee grinder is grinding too fine. I would up the size of your grinder. The larger the numbers the coarser the grinds. Also, should descale the machine if you haven't in a while. One of these two things may help.
Also, if the above two things do not work you can try to clean out your grinder using the instruction #2 posted on the website http://cerinicoffee.com/Saeco_technical_documents.asp
Sales, Service and Information of Saeco Machines visit:
www.CeriniCoffee.com
Hope Everything works out for you.
Oct 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Mr. Coffee TFTX85 Coffee Maker Logo
1,924 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
