Question about Dell Inkjet 720 Printer
When I print PDFs on my Dell 720 Printer, the text is distorted.
SOURCE: Dell 720 printer won't print
I 've had this printer for four years, never used til now. Loaded new cartridges got color but no black ink. Put black cartridge in very hot water for several minutes changed the printing speed to high quality now it's working,
Posted on Sep 23, 2008
john_yap
  • 51 Answers
SOURCE: Can you help me install my dell 720 printer with
you can follow these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Posted on Oct 01, 2009
john_yap
  • 51 Answers
SOURCE: My Dell Photo Printer 720 has stopped printed, no
hi there,
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Posted on Oct 02, 2009
Nomodo4u
  • 863 Answers
SOURCE: My dell 720 printer has a new ink cartridge, acts
Take the plastic strip off the ink jet cartridge before putting the thing in the printer.  Check the ink jets to see if they are clogged.
Posted on Oct 25, 2009
  • 615 Answers
SOURCE: can i print documents on a dell 720 photo printer
your computer does not see the printer or you did not select the printer from the print program try to reinstall the driver and then connect the printer to be able to see it
Posted on Nov 08, 2009
Dell 720 printer won't print with color cartridge. I put a new color and B&W cartridge in and doesn't print. If I take the color one out, the B&W prints fine
I have the exact same printer and had to replace the print head. This dell 720 is a discontnued model and may or maynot be worth the $35 fix. the issue is the print head gets clogged up prematurely in these 720 series dell paperwights.
the best course of action:
1. purchase priont head
2. or buy a new printer
You can try print head cleaning kit but you may be wasting you time and money on the ket because it does not work 100 percent of the time.
thanks for your question, i would thank you for your ratings and feedback in advance!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 26, 2010 | Dell Inkjet 720 Printer
Pdfs not printing all of the text
Several issues may be responsible for this, one you may not have right to print or copy, please check from the file menu the document properties, check security.
The other is check the printer properties, click on fit page
Mar 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Dell 720 printer quit working. Acts like it's
Your ink cartridges are depleted. Refill them or buy new ones.
Feb 15, 2010 | Dell Inkjet 720 Printer
Can i print documents on a dell 720 photo printer
Nov 08, 2009 | Dell Inkjet 720 Printer
Dell 720 printer
Delete the printer icon and disconnect the USB cable. Restart the laptop, reconnect the USB cable to see if your laptop recognizes the printer. If so, install the printer driver. If not, probably USB cable or port issue. Hope this helps.
Aug 05, 2009 | Dell Inkjet 720 Printer
Dell 720 Printer failure
it may not really be the lever it may just need some lube. if you use some vasline and rub it on the bar and then move the printer head up and down put more vasline until the head moves slwly then try printing this may work.
Mar 04, 2008 | Dell Inkjet 720 Printer
Dell 720 wont print color
in setting s do u have it on print colers in black white only ?
Feb 03, 2008 | Dell Inkjet 720 Printer
Dell 720 Printer not printing envelopes.
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Jan 09, 2007 | Dell Inkjet 720 Printer
Dell Inkjet 720 Printer Logo
14 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
