Question about White Sewing 1866 Mechanical Sewing Machine
The bobbin compartment fell apart. I do not know how to put it back together or how to thread the bobbin
SOURCE: putting the bobbin housing back together
Found your problem while I was trying to solve mine. I can solve yours. Here is the page from my manual about how to remove/replace bobbin housing. I hope you can make this image larger so you can see it clearly. We're limited as to the size of the file we can upload.
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: White Sewing 1632 Mechanical Sewing Machine
you do not have the bobbie lined uo with the needle
Posted on May 29, 2007
informatica
  • 1114 Answers
SOURCE: putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
I have a old Brother's sewing machine. Its an old machine never used due to me not being able to thread and do the bobbin correctly. Well, I went on YouTube recently and learned how to correctly thread and...
Try a new needle(inserted all the way up and flat side facing the rear of machine) and taking a hair dryer to the bobbin area to heat it up. . If, that doesn't work, try cleaning and lubricating the machine as per your manual. I am hoping that the timing is not messed up because that is not a do it yourself job. Sometimes, lack of use causes things not to move so good, like us, LOL. Good luck
Dec 31, 2010 | Sewing Machines
I can seem to get the bottom thread up
Try replacing the needle. sometimes a bent needle causes this.
It sounds like your timing may have been altered when your bobbin housing fell apart. This is difficult to repair without specialized tools and knowledge, so best get it to a repair shop.
If the machine is a common brand like Singer or Kenmore, go online and search for a manual. Many are available for under $10 or are free to download.
Nov 02, 2009 | Sewing Machines
Bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Jul 31, 2008 | Brother XL-5130 Mechanical Sewing Machine
Janome 7000
there is a little switch at the back behind the needle. I had the same problem and after i wiggled this switch it s now working. Hurrah!
Jan 10, 2008 | Janome Memory Craft 5700
Putting the bobbin back together
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
White Sewing 1866 Mechanical Sewing Machine Logo
144 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
