Question about Samsung SyncMaster 2233BW 22" LCD Monitor
I have a syncmater 2333 HD and after connecting to my pc, i seemed to have lost all sound. when connecting speakers and earphones, there is still no sound. thanks
    Scholar:
  • 92 Answers
Did you plug in the audio cable to the back of the computer? If so, this may have disabled the front audio connections (or vise-versa). Try unplugging the audio cable from the computer (that is connected to the monitor) and see if your headphones work. If so, there is the solution to that problem.
Check the audio connection on the back of the monitor and double check that it is plugged into the correct port on the back of the computer. If the monitor has amplified speakers, it would be a good idea to connect to the 'line-out' connector on your computer. This would avoid disabling your front audio panel.
Lastly, check the volume on your monitor's built in speakers. This monitor can double as an LCD television, so it most likely has a separate volume control (that defaults to 0).
Posted on Oct 04, 2009
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
I have an hp 2011x monitor. How do I connect earphones for sound ?
If you are asking about where to connect the earphones to the monitor, you can't. As far as I can determine this model monitor does not have an earphone jack nor built in speakers.
This is a great HD monitor, but you will have to plug the earphones into the jack (green plug) on the front (and/or back) of the computer to get the sound.
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 05, 2011 | HP Computers & Internet
How can i (i-mate jaq3) connect to pc whith data cabal because lost my cd software
Go to this link for a free SyncMate software download for your phone and then after its installed you will be able to connect and sync your phone with your pc. Link Below
http://www.software112.com/products/syncmate+download.html
Nov 25, 2010 | i-mate JAQ3 Smartphone
While using my remote to change channels, it lost the sound and I can't seem to get it back on.
If you didn't press mute or some other feature that turns your sets volume down. It could be your audio amplifier chip has gone bad. If you have a theater system or some kind of gaming system plugged into one of the RCA jacks try unpluging them. If your set has a earphone setting and you accidently set it to earphone mode check it and put it back on speaker mode.
Aug 05, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Oct 25, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Cannot detect when a jack is plugged in.
check your sound card ,,do u have sound threw the pc speakers.if so bad head phones.or not compatable with your pc.
Oct 09, 2009 | Dell A215 Computer Speakers
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
The sound on both my old IBM laptops (T40 & X31) no longer work.
Try pressing the sound up button on the top of the keyborad. There are 3 buttons sound up, sound down and mute. It appears that the sound control on windows is independant of the buttons.
Apr 11, 2009 | Lenovo ThinkPad R51
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
530 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
