Question about Eclipse SW9152 Car Subwoofer
WHERE CAN I FIND ANOTHER SUB LIKE THIS? - Eclipse SW9152 Car Subwoofer
  • yadayada
    yadayada May 11, 2010
    we are not a parts locator.
    Genius:
  • 1,144 Answers
Look on ebay .
Posted on Oct 05, 2009
How to put geometric sequence in this calculator?
Are you trying to find a particular term in the geometric sequence?
For example, in the geometric sequence 2,4,8,16 to find the 15th term we would use the formula a sub n = a sub 1 x r ^(n-1), where a sub n is the nth term of the geometric sequence
a sub 1 is the 1st term of the geometric sequence
r is common ratio between successive terms
n is the term you are looking for
In our example, a sub 1 is 2, r is 2 and n is 15.
a sub 15 = 2x 2(15-1)
a sub 15 = 2 ^ 15
a sub 15 = 32,768
On your calculator, you use the key to the right of x^2 to do x to the nth power.
Good luck.
Paul
Geometric Sequences and Series
casio fx 300es manual Google Search
Jan 12, 2016 | Casio fx-300ES Calculator
Pre-out for sub in-op
first make sure the actual sub is powered on .You can tap on the RCA leading to the sub and hear the sub humming..Im assuming you do have a powered sub connected to sub out of receiver .Also you could also connect another type of speaker with RCA to make sure if it has output or not..Also make setup does have sub output ON..thanks
Dec 15, 2007 | Audio Players & Recorders
How to lower front sub frame on 2002 mercury sable
support car place jack stands under sub frame. using an engine support to hold motor in place, disconnect anything that is attached to sub frame, ex: motor mounts. then unbolt sub frame bolts(4) and raise car to remove sub frame. note sub frame is heavy.
Jun 24, 2015 | Mercury Cars & Trucks
How to trouble shoot a sony sa-wm20 that stopped working
With subs, it's either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
You've ruled out most of this because another sub works in its place. So what's left is either sub settings, or a busted sub.
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
Most subs auto sense a signal. So if the Sony isn't doing that then there's the problem. Given that these are very much a budget sub, I'd be inclined to have a look for something simple such as a broken solder joint or bulging capacitor. If it's anything more indepth then the cost to repair will outweigh the value of a replacement.
Aug 05, 2014 | Audio Players & Recorders
How to wire it to make the bass cuts off when offing the eq
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Feb 13, 2011 | BOSS AUDIO SYSTEMS AVA1204 7Band Car...
Is the sub out strictly for a powered sub or is there a way to hook up speaker wired subs to that
The sub out connection is for powered subs. To use a sub that runs off of the amp power, you'll will have to run it through the main speakers. Usually, on this type of sub, there are connectors that allow the frequencies above the sub range to bypass it and go on to the main speakers (the sub filters the lows and passes the highs on to the speakers). If your sub does not have this, then you'll have to get a separate amp for your sub to run off of the sub-out.
Dec 01, 2010 | Sony STRDH710
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
Eclipse SW9152 Car Subwoofer Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
