Ruud IFC Furnace Blower comes on and stays running, never lites
Blower comes on and stays running and never tries to lite. Turned off the thermostat and now have it disconnected and as soon as power is restored to the furnance the blower starts running and never shuts off.
    Problem Solver:
  • 10 Answers
Check on the circuit board for an automotive type fuse that is probably blown. These fuses blow because of a short in the control wiring. If the fuse is blown a lot of furnaces run the fan all the time as a diagnostic. You will have to find the short or it will just blow again.
Posted on Oct 05, 2009
Ruud Furnace
Try jumping out the presure switch and see if it lights
Apr 13, 2012 | Heating & Cooling
The floor vents in our house are blowing cold air instead of hot. What can we do to fix it? What would be causing this?
If the furnace is running and the registers are blowing cold air you have a problem with the furnace. Check to be sure the pilot lite is lite if this is a standing pilot, if not check to see if there is a flash code in the site hole in the bottom blower door of the furnace. Be sure the thermostat is set to heat and turned up.
Jan 02, 2010 | Heating & Cooling
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ruud achiever 90 plus gas furnace
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Heating & Cooling Logo
324 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
