I went to unload my washer and there was soap and water almost running out the top. It won't drain out. Help!
  • cncfixxer May 11, 2010
    Look for a bent or kinked drain hose ... I know it sounds gross but try to blow in. it. It should have some resistance but not completely blocked If you hear the pump come on odds are something small (ie:sock) is blocking it or the pump. A hail Mary type fix may be to pull the power plug then hold the drain hose to the faucet and turn the faucet on ( you may get wet) sometime that will disslodge the blockage Good luck
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Try cleanung out filter.Drop down drain hose to floor level this will allow syphon of water away into bucket 1st,,Hope this is some help
Posted on Oct 04, 2009
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
May 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
There is water squirting out of a hole next the pressure hose connection. Is there a missing screw? Or an adjustment to the washer that can be made. There is no pressure because of this leak.
If this hole has threads then it might be the soap inlet. If water is shooting out under pressure you may have an obstruction in the hose/handle. Try removing the hose and running the washer and see if the water flows out the connection. If the hose ends up being the problem a visual inspection and cleaning of all inlets and the handle should clear it.
If the water coming out of the hole is low/tap line pressure then I think your bypass *(or unloader) valve is stuck in the bypass position.
A stuck unloader just needs to be unstuck and lightly cleaned. A light coating of silicon grease wouldnt hurt either!
Get the manual for this pump and see how to open/remove the unloader valve.
Jun 04, 2011 | Northstar Pressure Washer 3000 PSI
The washer is saying LE what does this mean. I had it on delicate cycle and now there is water in the machine and it needs to spin out. Help.
Apparently "LE" can mean a million different things - everything from "your drain motor is burned out" to "your drain filter is clogged" to "you used too much soap". I have found that usually it is the latter. I gather that what "LE" really means is that the drain flow rate is not high enough. Here's the quick fix that you hope will work, and that has always worked for me (knock on wood):
1. Get a 5-gallon bucket (or a little less)
2. Open the little door on the bottom left of the front (pry it open with a quarter, like it says in the owner's manual)
3. There is a drain hose with a plug in it. Pull out the plug and let the water drain into the bucket
4. There is a gross trap/filter in that same door. After draining, unscrew that filter, remove and clean out, then screw it back in place.
5. Replace the plug in the drain hose, and close the door back.
6. Try running the washer again, but don't add any soap. If it was the filter that was clogged, the washer will run to completion, everything is fixed, and you can start your free happy dance.
7. If it stops again and gives the "LE" again (likely), then drain the water into the bucket again, replace the plug, and start the washer at the beginning again without adding any soap. Usually by the third time I do this, the washer will run to completion and I can commence the free happy dance, followed by the gentle reminder to my lovely spouse not to use too much soap, that the washer actually cleans better with the right amount of soap, even on those extra dirty clothes.
Hope this helps!
Feb 21, 2011 | LG WM-2277HW Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
First washer would not fill tried later it started got to spin stop will not empty water tried drain and spin button still wont run help thank you happy hoildays joe thomas
Suds detection & long drain error codes indicate a problem with the water draining out or too much soap is being used. If the unit is not draining good then I would suspect a problem with the pump or control board. Please see the images provided for more details. Press stop twice to reset the control.
Dec 17, 2010 | Kenmore Oasis HE 27062 Top Load Washer
I've got Fisher and Paykel Excellence Top loader 7.5 My problem is, it won't unload or drain water. What do i have to do?
Hi, The washer wont unload or drain water until the drain pump is working. Get the pump off and look for debris. To remove the pump you unlock the tab and twist the pump a hair. The pump is on the bottom of tub.
Apr 13, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My Washing machine is retaining water in the bottom or back of the washer which is visible sometimes. It has mildewed and SMELLS! I have run the washer through the spin cycle several times and this empties...
Sounds like your drain hose is pluged with something. Try and check for small idem into drain on bottom of washer ( chain, braclet etc ) or soap buildup. Once you have determined wheather or not there is a plug to be removed, you can run cider vinegar through your wash cycle which will help reduce the mold. Plus it helps with soap clog buildups. Powered soaps tend to build up faster then liquid soaps do.
Feb 25, 2010 | Whirlpool Washing Machines
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Drain standpipe overlfows on eshausting water
The pipe is clogged and may need to be replaced or cleaned out. Over time the pipe will get a build up of dirt and soap that you can't get out.
May 19, 2009 | Kenmore 23822 Top Load Washer
Washer flashing F then went to SUD
Drop the drain hose so that it is lower than the drain and let all the water run out of the machine. Open the door and remove all washing. Let machine go through rinse cycle with some milk mixed in with the water, (pour the milk into the soap container, about one cup) and make sure there are no soap suds left in the machine. Check that you are using washing powder which is recommended for front loaders.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
