Question about Sony PlayStation Portable (PSP) Console
I can turn it on and you can hear it going through the different features when you press the buttons, but the screen is blank
  • 53 Answers
Call Sony
Posted on Oct 08, 2009
Treo 700w-Blank screen
You may have a faulty screen
Have you tried a HARD RESET?
Perform the following steps:
Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
Push the up button on the five-way to start the reset process.
Alternate process:
Similar to the hard-reset of the Treo 650. Remove the battery cover.
Press and hold the Red radio button.
Use the stylus to depress the reset button next to the battery.
Push the up button on the five-way when you get a prompt to "Erase all data".
Replacement screens are available on ebay.
Sep 04, 2008 | Palm Treo 700w Smartphone
The screen remains blank/black when i turn on my laptop
Somewhere on your laptop (usually in the function keys), there is a dimmer & a brighter button for the screen. Usually has a little sun icon on it. Try pressing the brighter (larger sun) and see if an icon pops up with a status bar (dotted line). Press the brighter key about 5 times and see if that makes a difference.
Aug 11, 2012 | Toshiba Tecra Computers & Internet
My hp G60-635DX screen is blank . When i turn it on i cant see anything its just blank screen. I can hear it turn on and if i was to type in my password it would go through and start up jist my screen is...
Try This and see if it resets the whole system
This works for a Sony Laptop.
Remove AC power
Remove Battery
Press the power on button for 30 seconds the release.
Install the battery
Providing that the battery has a sufficient charge, it should turn on. Mine did, and a Sony Technician provided the tip.
Good Luck
Jul 21, 2011 | HP Computers & Internet
After the tv is tuned to a new channel, a black square appears over the majority of the screen. The Direct TV tech said that it was a parental control feature that needed to be reset
Actually, your TV's closed-captioning is turned on and it's set to "text" mode. This causes the set to blank out the area where the text would go if there was any. Most remote controls have a single button to turn captioning on, so it's easy to get into this mode without knowing it. Press that button or use the TV menu to go through the caption settings to turn them off, and the box should go away. (Parental controls don't just blank out a part of the screen; they disable the channel completely. I hate it when a technician won't say "I don't know" and then gives out wrong information.)
Jan 01, 2011 | Philips 27PT9007D 27" TV
Want to turn the DND off
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Dec 08, 2010 | Panasonic KX-T7731 Corded Phone
I unplugged my ps3 to put it into a different room and it worked fine, then i put it back in my room and now it comes up with a blank screen?
Connect your controller into the USB port and press the `P` button.
If still no joy, then hold the power button down at the front of the console until your hear one beep then eventually another. When the PS3 shuts down, let go of the button.
Then press and hold it again until you hear the first beep, 2nd beep then a double-beep.
This will bring up a 6 option menu, select `Restart System`.
This should sort the problem!
Good Luck!
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Sony PlayStation Portable (PSP) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
