Question about Maytag Neptune MAH5500B Front Load Washer
Water stays in front load washer and does not spin
    Genius:
  • Maytag Master
  • 1,466 Answers
Try filter clean,,,,,good luck
Posted on Oct 04, 2009
My washer will fill up but wont spin and the water stay in
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Whirlpool Washing Machines
The wash machine washes but will not allow the water to go out, it just constantly spin and then slow down and start to spin again and again and the water stay in washer. It has a new timer.
heatman101
May 16, 2011 | Washing Machines
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 12, 2010 | Washing Machines
Washer won't drain
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not spin at all & clothes all stay wet??
motor brushes failed will need replacement cheap to replace.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
