Question about Refrigerators
I need a defrost timer, defrost thermastat and an element for a crosley refrigerator model # C521G2 The problem diagnosed by the technician
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 1073 Answers
SOURCE: Problem auto defrost refrigerator
loaded question any COULD be bad a volt ohm meter will tell you whitch one is bad
if this is a ge sxs i would check the defrost heater first
Posted on Jun 24, 2008
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Need a wiring diagram for a Whirlpool ED5VHEXTQO1
I will give the wiring diagram a try but your refrigerator has a simple defrost timer that is most likely the reason for your problem. Give me a few moments and I will give you a photo. Inside the fresh food compartment and behind the control panel is where the timer is located. Sea Breeze
Posted on Oct 23, 2009
Cs21a2
It sounds like the defrost cycle isn't working. If this is an older electro-mechanical model, the 1st thing to suspect is the defrost timer. They're not too expensive and usually easy to replace.
If it's a newer 'electronic' model, then it's very likely the cheap chinese control board (motherboard) has gone bad. However, replacements are NOT cheap to purchase, and may be more difficult to replace.
Other parts that could be suspect in the defrost cycle are the heating element and thermistor. The cold control could also be a suspect. If you don't know what or where these are, it's best to just call in a technician.
Jun 29, 2014 | Crosley Refrigerators
Drainage tube plugged
It sounds like the defrost cycle isn't working properly. If this is an older electro-mechanical model, the 1st thing to suspect is the defrost timer. They're not too expensive and usually easy to replace.
Other parts that could be suspect in the defrost cycle are the heating element and/or thermistor located on the evaporator, and possibly the cold control located in the fresh food section. If you don't know what, or where, these items are, it's best to just call in a technician.
Jun 16, 2014 | Crosley Refrigerators
Refrigerator leaking
very simple solution there is a drain cup usually in the fridge at the top by the lights or on the back wall make sure it isnt plugged . now the other thing you will need to do if that cup isnt plugged is pull the fridge out from the wall there will be a black or white tube running down your fridge to a tray or a dish on top of the compressor that is your drain it runs over the compressor so the heat can evapourate any water make sure its not plugged and water can run out of the tube . if you go inside the fridge and that drain cup is covered in ice then u have a defrost problem will need a technician to replace either the defrost timer or heating element or your thermastat good luck
Oct 02, 2013 | Whirlpool Refrigerators
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a samsung rf266abbp and the freezer is ultra frosty. this just started this week. the unit is about 1 year old. does it need to be defrosted. if so, how?
Hi, if freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model)
Take care
May 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer section is cold, but the refrigerator section is not
Aug 23, 2009 | Refrigerators
Freezer and refrigerator top part does not cool, only bottom.
Aug 22, 2009 | Jenn-Air JCD2290HES Side by Side...
The refrigerator side has stopped cooling.
Aug 18, 2009 | Refrigerators
Refrigerator cools fine but the freezer does not. It stays at about 20 degrees f. It is a GE
Aug 16, 2009 | Refrigerators
My ED5HHAXVQ02 refrigerator is not cooling. However the freezer is overfreezing and frost is building up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
