Question about Magic Chef CTB1821AR Top Freezer Refrigerator
No power and outlet is hot. Light or compressor not on?
    Problem Solver:
  • 17 Answers
Change the light bulb see if it comes on, if not line cord is probably bad
Posted on Oct 04, 2009
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ugolini slush machines
check the left side condenser coils, make sure they're clean. there might be low air flow, and that'll cause the compressor to overheat and shut off. leave at least 6 inches of space on both sides of the machine for it to breathe. also if the ambient temp is too hot, same thing.
Jun 26, 2014 | Kitchen Appliances - Others
Chest Freezer not wokring
Sounds more like a neutral fault if you have power there but no lights are working. Check each wire from the plug to the junction in the cabinet, then check to the lights and thermostat.
Unless you have a capacitance tester, you need to substitute a good capacitor in line to see if the compressor starts. If it was the capacitor at fault, the compressor would be trying to start every 5 mins or so and would be hot to the touch.
Jul 22, 2012 | Freezers
I noticed the steel braided hose which is the intake for the air supply is very hot to the touch. Like extremely hot and was just wondering if this was normal? I removed the air filter and tried running...
I believe the hose you are referring to is the "Aftercooler" that connects from the head (outlet) of the compressor head to the air tank. Under normal use, the aftercooler will get very hot. Air is heated when compressed and will heat up this hose and the inlet area of the tank.
Oct 15, 2017 | Dewalt D55270 gas powered air compressors
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring...
This is not good wiring option. It is not good to have light and outlet on the same switch without different fuse. I suggest to insert another little switch on light connection. Than you can have control of both. Or you must find main phase (hot wire) inside switch box. This will be always on for tester when you try different switch position. When you find this main (hot) wire, you disconnect one of another two wire (after you disconnect power), than give power on and test light and socket (one of them will not work). If this is outlet, you must connect this wire to main (hot) one. Don't work when power on. Just test it with tester, and than disconnect when you change position of wire.
Good luck and be careful!
Aug 26, 2011 | Electrical Supplies
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore chest freezer
check light inside .on? you got power. check compressor in back on? if no then you probably have a bad stat. open door and look inside for numbered dial. turn max hot to max cold back and forth. if compressor comes on you need a new stat probably. remember only a stat a compressor on these units. if its hot stat should send power to compressor. if power is arriving at compressor and not running then start relay and or start cap are probably bad. but if compressor is running and still no cool then your probably out of freon. unfortunitly these boxes are made with steel tubing in the cabinets. when you move them lots of times the tubing rusts and ruptures. then your all done. new freezer time. they are sealed to the point there are not even a place to apply gages to check charge. you can gently remove power and then stat and jump thermomstat to take it out of equation and if compressor runs you need a new stat. constant power comes in one side of the stat and when the sensing tube is heated it closes the points to the outlet side and puts power to the compressor. there may also be a ground wire usually green be sure to observe which two are power in and power out. usually side by side. good luck
Oct 25, 2008 | Freezers
Amana side by side refrigerator
If the unit is on a ground fault outlet move it to a different outlet or change that one out. A refrigerator or freezer is not reccommended to be on a GFI curcuit. Your hot compressor start can be close to 20 amps. That will trip any GFI it would be hooked up to.
May 20, 2008 | Refrigerators
Magic Chef CTB1821AR Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
