Question about Kenmore Oasis HE 27082 Top Load Washer
I have the kenmore elite oasis he model # 28062. It is almost a year old and I have been noticing when it spins out it sounds like there are loose coins clanging around in it, but there is not and it is coming from the back of the machine. Do you know what it could be?
  • 15,935 Answers
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Sounds like loose pieces clicking inside washer during spin cycle
Can you tell from the sound if the noise is near the bottom or not? The sound could be from something stuck in the pump. If you can post the whole model number, I can find more information..
Aug 06, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore elite 110.2706 unbalanced load problems
I have the same problem with my washer though it is a Maytag. the part that grips the drum to spin it is stripping, (and not properly grabbing). Repair man said to just get a new but I'm sure if you find a dedicated enough repairman he may be able to replace that part. The repairman said to replace mine because it was over 8 years old.
Sep 08, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Want to purchase & Install the see-thru lid on my 28062 washer.
Head over to the manufacturer's website.
www.searspartsdirect.com
Enter the FULL model number, and they will show you an expanded parts diagram along with ordering information.
Mar 22, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,023 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
