Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB600BC, only completes ~25% of brew cycle (based on water level
1-4 cup button not on
  • 464 Answers
Run some straight white vinegar through it and when it starts to pump through shut if off for a few hours and let the vinegar sit in the tubes. start it up again and let it finish. run the same pot of vinegar through again about 2 more times. then rinse with cold water about 4 times through and see if this helps.
Posted on Oct 04, 2009
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
We need to restart our grind and brew 5 or more times to complete a brew cycle/ get all of the water to go through. Is there a way to fix this?
That was happening to me as well. I just ran a mixture of 1/3 vinegar and 2/3 water through a cycle. Worked great. It's the first time in a year that it completely drained the water. Make sure you follow the vinegar+water cycle with another cycle of just water.
Apr 27, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
What does it mean when the brew light flashes?
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Mar 25, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
320 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
