Question about Acer Aspire 5735 Notebook
My space bar came off and so did two little plastic rectangles the seem to fit into these little hooks. when i went to put the space bar back on, it wont go back on
  • 153 Answers
Try it place it in a proper place and press equally applying proper pressure
Posted on Oct 04, 2009
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
Bernina 130. The upper needle is working but it does not seem to be abLe to catch the bottom thread. Had this machine for 12 years so I know how to put the bobbin in. Any ideas?
Firstly, I assume you've cleaned-out under the stitch-plate and after removing the bobbin, have removed the hook/shuttle, cleaned the hook race and given the hook race a drop of oil. Whilst you've got the hook/shuttle out, just check that the point is not damaged. Also, if you've got the lightweight hook/shuttle often fitted to these machines (it's black plastic with a metal outer/point), make sure there's no needle damage to the plastic - sometimes this can catch the thread as the hook rotates, preventing the loop from being picked-up. After doing that, check if you can sew straight stitch with the needle in centre, fully left and fully right. If it works in one location but not the others, there could be a number of issues such as timing/synchronisation or possibly the needle bar is offset front-to-back so that there's too large a spacing between the needle and hook.
Nov 13, 2011 | Bernina Activa 130
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
The space bar seemed wobbly so i took it off to try and fix, and the clips and all came off. I am somewhat good at technology and figuring things out but i cannot get this space bar back on. How do i fix...
That depends on what kind of clips it used. Most laptops use these small plastic clips. Assuming it is not broken, you have to first connect the two plastic pieces together properly. This is noted by it laying completely flat and freely able to move around. Then place it back on the space bar as it will have slots it must slide into. Then place the bar back over the space it came out of with the plastic henge over the square space with a popup switch and press firmly until you here a click. It should lock into place.
If you continue to have trouble, take it to a professional. Something like this should be cheap and quick to get fixed.
May 14, 2011 | Computers & Internet
How do I put in a space when entering addresses, i.e., E Bridlewood Lane?
The space bar is like the space bar on a mobile phone i.e. like a wide rectangle with the top line missing.
May 13, 2011 | Garmin nuvi 1490T GPS Receiver
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
I took my spacebar off to clean it and i dont know how to put it back on?
There is a rubber part that is designed to spring up when you release the space bar - this is the contacts that is the electrical push button. At each end the metal bar is hooked to the plastic (the long space bar key). There may be a couple springs found as well - they should seat on the base. Connect all pieces and place the space bar key over the area where it aligns to the keyboard and snap it place with a slight force.
Nov 23, 2010 | Compaq Keyboard
Can't put the playskool busy poppin' pals back together.
My boy put a little car into one of the animals, so I had to open it to have a look. mujin.jpg
Mar 28, 2009 | Playskool Busy Poppin' Pals
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
How to hook my sony VAIO to TV via HDMI
Hi there Dream,
There is a toggle function for switching the display. It cycles from normal to external to both.
You are looking for one of the F-Keys (Normally F5) should have a little rectangle between two vertical lines. It's supposed to be a monitor.
To cycle the display, press the Fn key (near the space bar), then the F-key. Your standard display should go blank. To get it back, do the same thing.
If your TV still displays nothing, Check which input its using.
This should get you going.
Mike
Dec 08, 2008 | Sony VAIO VGC-RB42G PC Desktop
Acer Aspire 5735 Notebook Logo
261 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
