Question about Frigidaire ATF6000ES Front Load Washer
ATF7000E50 door switch will not allow machine to turn on
  • 464 Answers
Sounds like you need to replace the door switch assembly.
Posted on Oct 04, 2009
Miele W1714 The machine says "Close the door", but the door is closed! All I can do is switch it off. Nothing else works.
There is a switch in the door that will make the door is ajar light stay on, if you no what door it is your going to have to replace this switch.this happen to me on my ford expedition
Aug 31, 2015 | Washing Machines
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
When I turn it on no lights appears unless the orange light on the washing machine door
There is a switch on the washing machine door that if not in proper adjustment will not
allow the washing machine to run. Adjust or replace the switch.
Feb 25, 2011 | Washing Machines
I have a GE washer which the agitator and tub do not spin. I can turn both freely by hand. The belt is in tact. During the cycle, the motor just osillates a minute amount in both the clock and counter...
it might be the safety switch under the door.
it is a switch that will not allow the spin cycle to spin unless the door is closed - like when you look in your washer while its spinning and as soon as you open the door the spinning stops until you shut the door again.
if its damaged it will not allow the spin cycle to work.
try look under the lid.
costs around $3.00 put in with a screw driver good luck
aloha
Feb 13, 2011 | GE Washing Machines
I have a hotpoint wml 540 p/g/a/k and the cycle will not start. The machine allows me to turn it all on etc but when i press the start button the door does not click and the red key symbol flashes. There...
I have had this problem with mine. Turn off the machine at the mains (might be awkward if the switch is behind the machine!) wait a couple of mins and then turn back on again. It should now work!
Nov 16, 2010 | Hotpoint Washing Machines
It buzzes and error or pause comes on wont spin, wash anything water is in the machine. I tried lightening load. not matter what cycle I try. Tried turning it off. Door is shut dispenser is...
Since your machine is not giving an error code, your problem is probably a defective door switch. They fail fairly often in your model. It's an easy repair, at least! The electrical switch is what "catches" the latch (striker) from the door and holds the door shut during operation. To replace, first remove the top lid by removing the two screws in the back and sliding backward. ( Looking down from the top/front, you can see the switch.) Then, remove the two screws holding the door switch from the front of the machine. This will allow you to bring the door switch up. Note how it's wired and reconnect the wires the same way, one at a time, to the new switch. Replace the two screws from the front, reinstall the top lid, and you are ready to wash!! Good luck.
Mar 27, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Oct 04, 2009 | Washing Machines
Ge washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE Profile Prodigy WPSE4200A
Whirlpool Duet GHW9150P
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
usually switching off at the mains and the machine and waiting for a few minutes should do it. Make sure the programme select dial is at the correct position. Have you tried emptying out the water first? (either by putting it on a spin cycle or physically removing the outlet hose from the pump and catching the water in a basin or bucket)
Mar 23, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
