Question about Linksys WRT54G2 Wireless Router
Unable to write network settings to device - windows cannot save your network settings to the selected device? Not sure what we have done wrong
    Problem Solver:
  • 19 Answers
Which network settings are you trying to write? In general, try getting Network Magic. It's a free download and trial and can help with some Linksys/Cisco problems.
Also, you may try getting into the firmware itself. Use any web browser and enter the following IP address as your URL: 192.168.1.1. At that point you're directly accessing the settings on the router and should be able to make any changes you need. By the way, this only works if you're connected directly to the router via Ethernet cable.
Posted on Nov 08, 2009
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Compaq 610 windows 7 is unable to detect network
Click on the "Start" menu and selecting "Control Panel."Click on the icon that reads "hardware and Sound." Then, select the tab that reads "Bluetooth Devices." Click on the "Add" button. This will put your computer in "Search Mode." This means that it will search for any compatible Bluetooth devices in the area. Put your Bluetooth device in "Discovery Mode." This can be done by pressing and holding the button on the side of the device. This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop. Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 21, 2013 | HP Compaq 610 T5870 156 WH248UTABA...
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
Can't connect to wifi. Wifi is visible. The Wifi functions in other netbooks and laptops.
If you see it, you should be able to click on it. Make sure you have the right password, if it asks for one.
If you are unable to connect even if you have the right password, then maybe you connected earlier to that network and something went wrong and some settings are meesed up. We will have to remove these settings, then you can add that network again.
Not sure what operating sytem you have, so I will advise you for both xp and 7 (vista is similar to 7)
XP: http://www.tp-link.com/support/showfaq.asp?id=186
7:
This is the way to do it:
1) Go to Start and click on Control Panel.
2) Proceed to click View network status and tasks in Control Panel window.
3) Network and Sharing Center window will appear, proceed to click Manage wireless networks on left panel.
manage-wireless-networks-win7.jpg4) Manage Wireless Networks window will appear, and here you can see all available wireless network connection profiles. Select the profile , click on Remove to delete the selected profile. That's it!
Then go and view all available networks around, and try to connect again.
May 05, 2011 | Samsung N150 (36725723009) Netbook
Hi - I recently set the security on my router but am having trouble connecting to wireless on my home laptop. All other devices seem to be ok (2 work laptops, IPad, Ipod) and I get a message saying that...
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Jan 04, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
How get the internet on my laptop from my wireless router
Hi Friend,
Make sure you have connected the laptop to the router with a ethernet cable and then follow the steps to configure the wireless settings:
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and cloe this window.
4. Open the web browser and type the default gateway and hit enter. Enter the username and password.
5.Click Setup Tab then Wireless and then click Manual Wireless Network Setup at the bottom.
6.Make sure you fill/select the fields as mentioned below
* Wireless band:2.4 GHz
* Check the enable wireless box and make sure Always is selected.
* Type any name as per your choice in Wireless network name.
* Check the Enable Auto Channel Scan box.
* Select best (Automatic) in Transmission rate.
* Channel Width 20Mhz
* Select Visible in Visibility Status
* Security Mode: WPA Personal
* Select WPA only from the drop down of WPA Mode.
* Select TKIP and AES from the drop down of Cipher mode.
* Type 3600 in Group Key Interval
* Type any ten digit number as the password to connect your wireless devices and note it down.
Once done, click Save Settings. use the password (which you have noted down) to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 10, 2010 | D-Link DIR-825 Wireless QuadBand Router
Trying to configure device and i get this Says"
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Nov 02, 2010 | Belkin Basic Wireless Router
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
Dec 27, 2009 | Computers & Internet
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
Linksys WRT54G2 Wireless Router Logo
1,229 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
