Question about Garden
I need to adjust the clutch/brake on the tractor. 917.271013 15.5H Kohler. I'm not handy. Manual show how to which looks pretty simple. questions is where is the adjustment they are referring. Is under the tractor?? without a working brake I have not way to get under it. Any ideas? The tranmission is a 6 speed manual when the clutch/brake is pressed completely the tractor should stop but doesn't.
  • 389 Answers
You need a firm flat level surface such as a driveway or even a sheet of plywood.
Reach in under the tractor in front of the right rear wheel and locate the long rod that actuates the brakes.
At the end of this rod, there is a flat arm that goes down to the transaxle with a round disc about 3 inches in diameter behind it.
Near the bottom of the flat arm, you will see a nut in the center. Using a 1/2 inch wrench, with the engine off and the transaxle in neutral, begin turning the nut in and rolling the tractor back and forth at the same time just until you can no longer move the tractor. As soon as you reach that point, reverse direction and loosen the nut 1/2 turn.
You only need to move the tractor back and forth about 12 inches so if you are worried about it getting away from you, line up a 2x4 block in front and back of the opposite rear wheel
Posted on Oct 04, 2009
Clutch spring fell off. where do I attach it back?
if you don't get under it and look , would it do any good to be told . there has to be a place for both ends , one one the clutch /brake and the other the frame .
Apr 20, 2016 | Garden
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Engine starts when clutch is depressed but stalls when the clutch(brake) is released>
Start with a simple thing first, make sure the connection block to the seat micro switch is pushed completley on, if it moves back even a few millimeters you will get this problem, if this does not work check/replace the seat switch, if no better it could be one of the relays situated under the bonnet by the side of the fuel tank, they look like 2" square black boxes, they will just pull of the connector block with 5 or six pins.
Oct 09, 2012 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
How to fix gears on riding lawn mower
First: check your drive belt. Don't have the product manual? Download it from the Sears or Murray website. Second: Check your clutch/brake linkage. The clutch may need adjustment. Procedure on manual. The clutch wears over time and needs to be readjusted.
Nov 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No forward progress
first thought would be the brake sticking or the belt slipping, but then you said the fluid has been changed regularly [i'm guessing this is a hydro trans?] did you change it? what fluid did you refill it with? most hydros use regular 10w-40 motor oil, few use ATF. you could have some air in the hydraulic system and that will cause loss of power. to purge the air, pull the trans bypass rod out, start the engine, release the brake and move the shifter slowly to the forward position, then slowly back and to reverse, do this about 10 times, it should purge any air trapped in the system
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
242 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
