Question about Sony Cyber-Shot DSC-H1 Digital Camera
Camera will not stay on. Batteries are fine.
I got a dx4530 w/easyshare Dock II. from a friend of mine. He had been using AA batteries and it worked fine. I went to Best Buy and bought 2 Ni-MH batteries and put them in the camera. I then put the...
In the Kodak cameras of that vintage the original 3V rechargeable battery was made of 2 regular AA rechargeable batteries and a special piece of plastic that pushes some microswitch in the battery compartment. If this piece of plastic is missing, the dock would not charge the batteries. You either need the special CRV3 battery or to charge the normal AA rechargeables with a separate charger.
Sep 18, 2011 | Kodak EasyShare DX4530 Digital Camera
When I turn the power on the lens extends out of the camera and the power on light immediately goes off. The lens stays extended. no photo can be taken. This is a SonyDSC-P73 camera.
The only time that happens with mine is when I am low/out of battery power. I usually have to replace the batteries (even if the lens is still out) and then it works fine. Find it happens more often with rechargeable batteries because they still have a bit of power left, where regular batteries have nothing left after they 'die'.
Mar 05, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
The red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it...
he red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it has the same problem as before.
Feb 14, 2010 | Kodak CD43 Digital Camera
Camera wont stay on
I have the same problem with my camera. Any solutions would be great.
Oct 06, 2009 | Pentax Optio S10 Digital Camera
It doesn't work
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Aug 30, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak M1033 shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 03, 2009 | Kodak EasyShare M1033 Digital Camera
Dsc hi start up trouble
try new batteries. I was having the same problem and I recharged my batteries a few times and now the camera is working fine.
Sep 17, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
My camera is broken
dear samanthaj
My camera did the sae thing until I got duracell recharables. IT WORKS PERFECT NOW,,, as far as the camera staying on. TRY I..they're gREAT
May 30, 2008 | Samsung Digimax S630 Digital Camera
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Sony Cyber-Shot DSC-H1 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
