Question about HP Photosmart C6180 All-In-One InkJet Printer
C6280 Not printing in black
Suddenly will not print in black, run all the tests, cleaned nozzles, new HP cartridge, all drivers are up to date. Ran print allignment and it failed..only printed part of black rectangle....no idea what to do next...
tom19511
  • 1601 Answers
SOURCE: cartridges wont allign?
Try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en
Posted on Nov 12, 2007
SOURCE: HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Posted on Jan 11, 2008
sauruman
  • 7 Answers
SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Posted on Feb 21, 2008
SOURCE: Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Posted on Feb 25, 2008
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Posted on Aug 04, 2008
Black ink ran out, replaced it with new brother cartage and now it only print part of the text
Run a cleaning cycle on the print head through your printer utility. Then run a check nozzle test to verify if the nozzles are cleaned. Use only denatured alcohol and a Q-Tip to manually clean the cartridge holder & orifice.
Mar 26, 2017 | Brother Office Equipment & Supplies
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
Feb 19, 2015 | Epson Stylus Office Equipment & Supplies
HP Officejet Pro L7555 will not print black ink
Replace print head(black & yellow) or try to clean the nozzle.(try youtube videos for cleaning)
May 19, 2014 | HP OfficeJet Office Equipment & Supplies
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
HP Photosmart with FAX C410B. When I do an alignment test is comes up with the error message 'alignment failed'. I have tried taking the cartridges out and cleaning them but this has not worked....
Best thing to do is use the printer driver software to do a nozzle check. If the output has a problem, run the procedure to clean the nozzles. There is also the possibility if you are using refilled cartridges the quality of the cartridge housing has itself deteriorated making changes in the nozzle & air hole so the only way you can confirm is by using new original cartridge replacement.
Jun 30, 2011 | HP Photosmart C5180 All-In-One InkJet...
My hp t65 will not print in color. I've changed
Make sure you removed the sticky piece of tape that covers the print nozzles on a new cartridge.
Sep 17, 2009 | HP OfficeJet t65 All-In-One InkJet Printer
Will print only color. will not print black with a
First print a test page to make sure the printer's firmware is working correctly. See here. Check here to see that you have the most current driver installed for your OS.
Then use this article to set the print properties to print in grayscale using the black ink cartridge only, and test the printing.
If you get no output from the black cartridge, see this article or this article for help with cleaning and checking the cartridge contacts. Make sure the tape is removed from the cartridge nozzle. You may try running the auto clean utility a couple of times, but be aware that this consumes ink, and if you are not getting black printout, it's likely that the print nozzles are clogged with old ink. Sometimes even a new cartridge can be out of date, or have been stored incorrectly, and cause this.
I've read of cases where people were able to use a vacuum nozzle to clear clogged cartridge nozzles and get them operating again, but haven't tried this myself, and recommend if you do you attempt it in an environment where ink can be cleaned up. (See here for more on that.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
Color suddenly won't print
Big nozzle clean up session. Run the correction software. Remove the cartridge[s] and assuming they are full[ish] stand it/them nozzle down on a damp tissue. If this model is head in cartridge, make sure the contact film is clean and undamaged Reinsert try some more Also look at www.fixyourownprinter.com
May 11, 2007 | Canon S200X Ink-Jet InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
