Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Fridge blowing breaker
We just purchased a used fridge for the garage .It was plugged in and working when we bought it. We loaded it up ( no it was never on its side or anything like that) and brought it home. As soon as we plugged it in it blew the breaker and it keeps doing it. Help!!! What is wrong?
  • Maytag Master
  • 5,568 Answers
Our son had the same problem; we saw it running and working in the garage of the seller and once at home, it kicked out, not the breaker, but the GFI (Ground Fault Interrupter). I checked the resistance from (earth) ground to the hot and neutral side of the AC plug and found it conductive. The problem was found; the defrost heater had gotten enough moisture inside to create a conductive path to ground. It wasn't dangerous (it would be a heavy 'tingle') but GFIs won't tolerate more that a milliampere or two to ground. I don't know if the seller knew of the problem since his garage receptacle was two-prong and not on a GFI circuit.
Make sure that this isn't the problem with your fridge.
BTW, I recommend to all that they buy a low-priced digital multimeter; they are under $20 US and can be found at any auto parts store or Radio Shack. Having one of these around you can pretty quickly locate many electrical problems in the home and vehicles. You only need the most basic one you can find and they come with adequate Chinglish instructions.
Posted on Oct 04, 2009
    Sergeant:
  • 316 Answers
Try plugging it in somewhere else with nothing else on that breaker. No extension cords. My air compresser sometimes does the same thing due to a large power draw.
I moved a perfectly working KitchenAid fridge from inside the house to the garage and now it blows the ground fault breaker the second it is plugged in.
Almost definately, there is a wire or more accidently pulled loose while carrying the fridge.Check where the cable enters the fridge and the surrounding area.
Jul 19, 2010 | KitchenAid Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
High voltage
Great, JP. Could I ask you to please rate my assistance. Thanks very much!
Charlie
Aug 20, 2009 | Coleman Powermate Powermate 5000W...
FRIDGE IS BLOWING THE CIRCUIT BREAKER
Most likely you have a bad or weak circuit breaker. Consult an electrician for breaker change out. Make sure that it isn't hooked up with a GFI plug. They will not work on a GFI.
Apr 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
My Maytag MTF2172HR* keeps blowing the fuse
You guys are gonna LOVE this one.
I called a local appliance repair man, who said it sounds like the compressor.
He went on to tell me if it was the compressor, I would have forked over $75.00 to him, and, now need a new fridge, as it's probably not worth to replace.
I was a bit angry, so, deciding what to do, I started snooping around the back of the fridge.
Everything back there looks brand new, and clean, so I was starting to think it wasn't the compressor.
I put in a new breaker in the circuit panel, and, still blew.
As I was behind the fridge, I grabbed the power cord, and felt something strange- looked down, the power cord was cut through and twisted, exposing the little wires inside, and, visibly crossing them.
So, I'm going to go to the appliance store, and see if they have a replacement power cord.
Thanks,
Sep 27, 2008 | Maytag 21 cu.ft. Top Mount Refrigerator,...
GARAGE FRIDGE DIED...IS IT THE COLD?
No it has no sensor it sounds like the circuit breaker has tripped or the is no power at the plug..try plugging a radio or lamp in to the plug to test
Jan 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
123 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
