Question about Garden
My scott riding mower 16 hp 42'' stopped while i was mowing,and will not start or turn over even with a new battery..help
  • 472 Answers
Have you tryed romoveing the belt on the mower deack to see if that biding up the moter if that dose not work try turning the moter over by hand let me know what happens
Posted on Oct 04, 2009
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
ENGINE WILL NOT TURN OVER, EVEN WITH A FULL BATTERY CHARGE AND JUMPER CABLES. THE STATER ENGAGES AND THE FLYWHELL TURNS ABOUT 1/4 REV. AND STOPS. IF I MANUALLY ROTATE THE ENGINE MORE THAN 1/4 TURN (PAST...
I am betting you will not believe this, but, your battery is bad. I just had the same problem last month. Same, same. I have always had good luck with jumper cables, but there was something wrong with the mower battery. When I removed it and replaced with new one, everything is as new.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman riding lawnmower will not start unless jumpstarted off the starter and while mowing the blades will stop turning even on the two highest setting for the deck and the grass isn' t that high?
Sounds like your starter is bad and that could be causing your blades not to work if you have a cvt type clutch. If you don't i would check your belt it may be stretched out.
Apr 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 46", 21 HP Craftsman riding mower. The
perhaps it is no oil or too much oil. Check oil level!
If it was too much it would be blowing oil or blue smoke out the exhaust.
Good luck! Hope this helps.
Ashman
Jan 03, 2011 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. ...
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Jul 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
LT1000 Will not start no clicking no turning over just dead
Do you have a multitester? A multitester set on vdc, should tell you if your battery has discharged. Should have about 12.5 to 13.0 volts for the engine to turn over. Could be a fuse, or bad connection. How corroded are the battery terminals?
Hope that helps.
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ys4500 Lawn Tractor will not start.
did you hit something while mowing if that is the case then check the flywheel key. even if it only has a small nick in it that would keep the engine from starting up...good l uck
Apr 11, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
