SOURCE: lexmark x5650
http://support.lexmark.com/perl/support/support.cgi
please click on this link, and type in your printer model to get the Chat support agent, who can fix this for you.
SOURCE: Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a Lexmark X5650 all-in-one printer. The
I strongly recommend you contact Lexmark Technical Support for assistance with that. If the problem is just the power supply of the printer, Lexmark Technical Support can send you one for free. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
