Question about Canon PowerShot A510 Digital Camera
The shutter freezes and the only thing that will work is the the ability of the lcd to open to the logo for a few seconds--batteries (including date and time) are fine.
5 Suggested Answers
arnomonfort
  • 115 Answers
SOURCE: No shutter actuation, no menu display, no autofocus.
check the battery and flash card doors. are they propely shut?
Posted on Feb 05, 2009
pontelemon
  • 531 Answers
SOURCE: LCD is black with camera on, new batteries, etc.
CCD is dead. Very common problem.
Needs new CCD.
Posted on Apr 21, 2009
t00nz
  • 4738 Answers
SOURCE: A75 Turn on the camera, no LCD display, It's black. The shutter is open, the batteries are new, I tried a new flash card, nothing works.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 17, 2009
  • 1382 Answers
SOURCE: every thing works bt no display on display window.
Hi, The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replcae the lense sensor for free of cost.
Posted on Apr 14, 2010
Testimonial: "thanks ...it helped me a lot"
Regardless of lenses,and batteries, cf cards, flash and exposure settings, when the fire button is pressed there is a small "click" and the camera freezes-no picture none of the exposure settings...
A few suggestions: The mirror lock up function has been activated. The sensor cleaning mode has been activated, doing this the camera as soon as you trip the shutter the mirror will come up and all other functions of the camera are inoperable. the mirror will stay in that position until it runs out of battery or you turn it off. The part you said about having to removing the battery doesn't make scents for this function though. Sensor cleaning is in the Custom Functions.
I know you said regardless of lenses and batteries how long do you wait before shutting the camera off and removing the battery? I know that's a question and we aren't suppose to answer a question with a question but the reason I'm asking is that the Canon 40D has a long 30 second shutter speed and a "bulb" setting. It is possible that the camera has been set to "AV" and the shutter is timing out, OR it's been turned to BULB and that mirror will stay there until the camera battery is dead before it drops. Couple things to check out before the next thing I'd think about is the amount of shutter actuation. The Canon 40D has a shutter good for 100,000 clicks/actuation. Sounds like a lot but if you are doing time laps or extended video it's very possible to blow the shutter out of these.
Dec 10, 2010 | Canon EOS 40D Digital Camera
Nikon D200 has become nearly impossible to grab images
False low-battery warnings, focusing, and metering problems may be the result of poor contact between the body and certain lenses. Try removing your lens and thoroughly cleaning the contacts. I would recommend using a contact cleaner, but rubbing alcohol will also work. Remember that the whole ring needs to be cleaned. If that does not work, try scraping the battery contacts.
Feb 01, 2010 | Nikon D200 Body Only Digital Camera
Shutter not opening
Check the date of your film. If its past two years from its experation date it is probably bad film. If refridgerated since it was purchased it will be good film to use. The self contained battery pack is also embedded in the film pack and the battery will also stay fresh if stored in a fridge
Jan 14, 2010 | Polaroid Spectra AF Instant Camera
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Ipod touch freezes at the apple logo
mine did the same thing. plug it into the computer. when it's open in iTunes, set the iPod to manual. sometimes when it's automatic, it'll clear itself out/freeze up until you plug it in again. this worked for me. it could be a glich, or their way of getting us to go onto iTunes more often.
Sep 10, 2009 | Apple iPod touch
May 05, 2009 | Canon PowerShot A75 Digital Camera
My laptop just freezes when working with it. i get a blank screen and the laptop freezes. sometinmes i get a blue screen and it just switches of
There are quite a few things that could cause this to happen. So, let's start with some basic possible fixes.
1) You could have a static build upon the mother board. Remove the power plug and battery. Hold the power button on for at least 30 seconds. That should drain the static.
2) There could be a connector problem. At very least,remove and reinstall the HD, DVD drive, memory modules,any PCMCIA cards flash drives, external drives and so forth.
3) If you have the tools and ability, I would suggest opening the beast up and reseating any connector that you can find including the wireless card and the CPU.
40 I hope not, but you could have a flaky mother board.
As I said, these are pretty basic ideas and hope that I've been of some help.
Let me know how you come out, or if you need more help.
Thanks and have a super day!
Ron
Dec 14, 2008 | Acer Extensa 5620-6119 Notebook
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Oct 26, 2008 | Vivitar ViviCam 35 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Canon PowerShot A510 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
