I was using my washer and it will get halfway thru the rinse cycle and stop. When I try to reset it nothing happens and it will not drain. Any ideas on how this can be fixed?
    Problem Solver:
  • 7 Answers
Probably needs a new pump fitting. You can drain manually by pushing a thin tube down the powder/conditioner inlet and sucking to syphon out.You can then remove clothes and work on the pump Its quite a simple job and a pump should cost you about £35($55)
Posted on Oct 04, 2009
Hello, I am Renee. My washer has stop draining and spinning after a comforter was washed. Would you please give me some advice/suggestions. Thank you.
Hi Renee,
Sounds like a blocked or faulty drain pump. Can you hear it trying to work during drain cycle?
A relatively cheap fix for most machines.
Thanks
Damien
Nov 08, 2015 | Washing Machines
Have a Whirlpool Cabrio washer WTW6400SW3 went thru wash wash cycle, then started to drain water to go into rinse cycle. Half way thru draining, was a loud electrical pop in control area of washer and...
sounds like a shorted machine due to water or moister? In most case you had a fuse blow on the machine somewhat like a thermal shut off fuse, most likely located in the panel. if this is the case u need to find out what shorted it, how water or moister got in? You can also look at the control curcuit board and look for burned seized transistors or areas indicating a burned out board.
Feb 11, 2015 | Whirlpool Washing Machines
My washer went through the wash cycle and into the rinse cycle and just stopped at the drain/spin part. When I pull the knob on there is a buzzing noise for about 10 to 15 seconds and then nothing. I...
I would call a local appliance store that sells and does repairs. Explain what's happening. They will probably be able to tell you if it needs service, and what type of problem it has.
Feb 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
