Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
Elite Plasma PRO-1410HD has a green line on screen
My Pioneer Elite Plasma PRO-1410HD has a green line running vertically on the right side of the screen. How do I fix this?? What is causing this?
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
SOURCE: Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Posted on Apr 03, 2008
  • 191 Answers
SOURCE: Bright Green Vertical Line on Plasma TV
two options 1 check ur power moudle for burst or swolling filter capacitors & check the electrolytic power capacitor in the primary side of ur power moudle .
Posted on Nov 09, 2008
Pioneer Elite plasma TV--top half of screen is green
What connection interface are you using. Can you try connecting another form of media and see the performance e.g connect to a computer or another TV box using another cable. If this persist, please visit a TV repair shop or call your manufacturer.
Jul 13, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Blue vertical line
Check your warranty, your LCD panel is going south
Apr 04, 2014 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Pioneer Elite Plasma vertical lines
Check for any loose connection at the COFs. Contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/Pull up older posts. Defective screenshots to plasma are shown. You can compare it to that of your TVs'.
Dec 21, 2013 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Why do I have green dots in the middle of the viewing area on my Pioneer Elite plasma flat screen?
Usually this is a issue with the main or processing board in the set but can strangely also be a power supply issue.
Causes include but not limited to: a voltage changing in the unit, a loose or bad connection on any board or if across entire screen even inside the display panel itself.
I would contact Pioneer to see if this is a known issue with this model. In our shop have been in this situation before and sometimes it ends up being---changing boards until you correct it.
Oct 22, 2012 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Red line on my pioneer elite pro-1410hd tv
It's burnt on to the screen if under 12 months call them and replace here you go /0871-964-0113
Dec 21, 2011 | LG DU-42PX12XC 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
I have a flourescent green vertical line about 12 inches
This is a problem that should be looked at by a local svc co. It could be the logic board, a buffer board or worse case scenario a bad plasma panel which is very costly.
Mar 04, 2009 | Pioneer PureVision Pro-1410HD 61 in....
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
168 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
