Question about FIC P4M-800T Motherboard
RAM upgrate I want to install the max. RAM on this motherboard . Can you tell me what type of memory I have to use because all memories are not compatible.
  • San Giorgio Dec 23, 2007
    I tried to install a set of 2 RAM 512 Mb DDR DIM PC3200-400 and they did not run together. They were working separately, one memory on one slot, and then one memory on the other slot but not two memories on both slots.
    I don’t know if this is a motherboard problem or a problem of RAM compatibility, but the system is working from the beginning with a set of 2 RAM 256 mb DDR.
    Do you have any suggestions about this?
    Many thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • FIC Master
  • 2,226 Answers
2 1g ddr400 low des. ram thats it jim
Posted on Nov 25, 2011
  • 35 Answers
You can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Posted on Dec 22, 2007
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Outdoorsman_197i have a memory problem with a ga-k8n -pro mother board i put a 1 gig stick of memory in it and it only shows it as a 256 stick and suggestions what could be doing this
    Here is the link to your manual which states that the motherboard should recognize up to 4 Gb of DDR ram, 1Gb max in each of the 4 slots:
    http://download.gigabyte.ru/manual/motherboard_manual_ga-k8n(pro)(ultra)-sli_e.pdf
    You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
    One way to find out for sure how much RAM is in your computer and how much it can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
    This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
    It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
    If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
    Hope this helps.
    Good luck.
    Apr 15, 2011 | Gigabyte GA-K8NS Motherboard
    We need memory upgrade to 4Gb jn MB GA-4MPSV. What memory module are supported by Transcend, Kingston, Samsung for This MB?
    This WEB site details the RAM modules you need and the prices.
    http://www.memory-up.com/memory/GigabyteGA-421376.html
    Apr 12, 2011 | Computers & Internet
    Cant open the tower. i want to add ram. what is the max i can add?
    One way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
    It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for that motherboard.
    Feb 22, 2011 | Gateway Computers & Internet
    I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
    here you go mate:
    Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
    Dec 01, 2009 | ASUS P4B533-VM Motherboard
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    Max RAM for Intel 102 GGC motherboard
    Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
    Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
    I need to know ram memory capacity and type of memory
    Easiest thing to do is go to www.crucial.com and run their Scan Program. It works well. It will tell you what kind of RAM you need, how much you now have and the max you can install.
    Mar 09, 2009 | Computers & Internet
    FIC P4M-800T Motherboard Logo
    228 people viewed this question
    Top FIC Computers & Internet Experts
    David
    David
    John Anderson
    John Anderson
    Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
