Question about Toshiba Portege R100 Tablet PC
Sometimes my screen goes off for no reason!
Sometimes my screen goes off on my Toshiba R100 netbook,but when I press Fn/F5 together,it comes back on.
Is it a loose wire somewhere? Thanks Doug
    Scholar:
  • 67 Answers
Check your settings in the display properties. The problem could be related to some display or power saver options. This applies if no reason means you do not touch your laptop when tthe problem appears. Otherwise it could be a wire problem as you have already supposed.
Posted on Oct 04, 2009
My hp tc4400 will not start up, I can hear the fan and the green button flashes any help would be great
Try pressing the fn key and F5 key together at the same time.sometimes the sticky keys just seem to kick in. if not F5 key it will be one off the other F keys dont forget fn+ F5 or other.
hope this helps
Aug 17, 2010 | Compaq tc4400 Tablet PC
I need to put the laptop on a monitor but screen
Usually FN and F5..............Try FN with other F? keys if it doesn't work with F5
Jul 15, 2010 | ASUS R1E-B1 Tablet PC
Trying to connect laptop to 46 in sony bravia, will show desktop but will not show the internet or anything else. please help
When you have the laptop connected to the telivision are you running both displays? In other words is the screen on for the laptop and the telivision at the same time? Sometimes if both displays are on you cannot run programs on both. When you use the FN key and press the display button(usually F5) it should cycle thru each time you press it. Try pressing it until you only have the display showing on the televison only. Doing this should make the telivision the main display.
Sep 08, 2009 | IBM ThinkPad X41 Tablet PC
Toshiba R100 suddenly very slow(!)
I'd suggest sending it back to where you bought it, this sounds a lot like a factory problem and it should be covered under warranty.
May 27, 2009 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Jan 07, 2009 | Toshiba Portege R100 Tablet PC
Taking apart a Toshiba R100
Probably, could have some slide catches at the top edge of the keyboard instead, need a thin blade screw driver oh lift the keyboard. Some laptops mark the screws with the letter K in indicate keyboard screws, some keyboard screws may be hidden under the battery pack, CD/DVD drive.
Nov 11, 2008 | Toshiba Portege R100 Tablet PC
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Nov 10, 2008 | Toshiba Portege R100 Tablet PC
Screen problems on Toshiba Portege R100
Right click on the computer's destop and view the display properties. Under the tab where you can alter resolution you can manage multiple monitors, It sounds like your laptop is setup to display through it's external VGA by default. Click on the two squares it shows and try to set your main screen as default.
May 30, 2008 | Toshiba Portege R100 Tablet PC
NO POWER ON
Try removing the battery and power cable then holding down the power button for 10 seconds. Reconnect the battery and power cable then press power again to turn on. It's usually a hibernation problem. Some newer toshibas also had a motherboard problem. I'd look up your model on the support section of www.toshiba.com and see if there is an updated motherboard driver install for your make.
Mar 31, 2008 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 Tablet PC Logo
144 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
