Question about Canon PowerShot A540 Digital Camera
I cannot get the screen to come up. it just shows the words auto.
Looking for word document I did not save
The power just went out while you working on an important document you forgot to save.
Do not panic because Microsoft Word comes equipped with a feature that automatically will recover files you did not save.
Typically, this feature works by default.
The program allows you to change how often Word saves your documents and you can adjust the location where Microsoft Word saves these "Auto Recover" files.
Open up Microsoft Word.
Do not click on a file to open the program.
Instead, open the program by double-clicking on the program's icon.
Allow the program to load for a couple of minutes before clicking on anything.
Look on the left side of the screen.
If Microsoft Word recovered the file, a "Document Recovery" task pane will load.
Find the file's date.
Double-click on the file in the "Document Recovery" pane.
This will open the file in Microsoft Word.
Click on the "File Menu" and select "Save As."
Save the document as a ".doc" file type, and type a name for your document in the "File Name" box.
or
Open Microsoft Word to determine if the program auto-recovered your document.
If your software is set to auto-save your document every couple of minutes, when the program is restarted, any document that was not saved prior to closing, may appear in the auto-recover window on the left side of the screen.
Click on your document, and the last-saved file will open.
However, anything you typed after the last auto-save is gone, but at least you haven't lost the entire document.
Search the auto-recover files manually if the auto-recover pane did not appear when you opened MS Word.
Click the Start menu at the bottom of your computer screen, and click "Search." Some operating systems have the search option as a part of the Start menu.
Search for "*.asd" to search for any recovered files.
If you find the file, open Word, and click "Open" in the menu.
Search through all files, and locate the file that ended in .asd. Click "Open" to view your file.
If you are using Word 2002 or 2003, you need to restart your computer after clicking "Open." Re-open Word after your computer re-boots to view the recovered file.
Check your backup files.
If you have the "Always create backup copy" option selected in Word, you may be able to find a backup copy of your document.
Find the location where you last saved the document.
Check for the extension .wbk.
If there aren't any, search your whole computer for files with that extension.
Open your file by clicking "Open" in Word, and search all files for the .wbk extension.
Once you locate the file, click "Open."
Look in the temporary files on your computer.
Complete a search for files that end in the extension .tmp by typing "*.tmp" into the search box.
Narrow the search down to specific dates of when you were working on the document.
If the file does not show up, try searching for the "~*.*" convention.
Some temporary files are in this format instead.
If your document is now in your temporary files, you will need to recover the damaged document.
Search for it within Word.
Click "Open and Repair" when you find it.
Hope this helps
Nov 06, 2012 | Computers & Internet
Open Microsoft Word if it's not already open.
This may automatically open a list of your recent unsaved files, which with any luck includes the one you're looking for.
If this happens, simply open this document from the list.
Click the blue "File" tab in Word, and then click "Info" on the left side of the screen.
Click the "Manage Versions" icon to bring up a list of options.
Click "Recover Unsaved Documents" from this list. This opens a list of your unsaved documents.
Select the document you're looking for in this list, and then click "Open."
This opens the document, which now has a yellow bar across the top.
Click the "Save As" button in the yellow bar.
Save your document with your desired name to your preferred location.
or
or
Hope this helps
Nov 06, 2012 | HP Pavilion Slimline s3600f Desktop PC
Previous monitor 13 1/2" wide. I want to make
Check on the monitor for an auto button or function, this should reset the screen resolution to match the pc output, what resolution are you running at? 640x480 or 800x600 would be my choice for that size screen but try some of the higher resolutions in conjuction with the auto button to see if you can get the screen size you desire.
May 05, 2011 | Computers & Internet
Auto word in texting
If you mean you want to enable the T9 Dictionary, you need to goto New Message, and press the # button 2 or 3 times consecutively until the Abc on the top right on your screen shows ___Abc. Those lines in front of it mean that text prediction has been turned on.
Cheers.
Mar 15, 2011 | Nokia 6350 Cell Phone
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Sound goes off for milliseconds
Try changing some audio options in the menu, look for MPEG, Pro Logic, Dolby. It may be set to Auto
Apr 27, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
The words PC showing on camera screen
Does the word PC show up with the camera connected or disconnected?
Feb 12, 2009 | Vivitar MAGNACAM Binocular
Auto-sap stuck on tv
I unplugged the tivo box and then plugged it back in.  This restarted it and cleared the problem.
May 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Canon PowerShot A540 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
